Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Simulink does not show DSP Builder menu
RubenPadial
새로운 기여자 I
2,178 조회수
I have installed DSP Bulder v22.4 and I'm trying to use it with Matlab R2015a(x64) and R2022a (x64) without success. Simulink menu does not show DSP Builder menu. Can anyone lend me a hand to configure it? Thank you in advance.
0 포인트
7 응답
Kshitij_Intel
직원
2,155 조회수
Please refer to the below link for the DSP Builder menu.
https://www.intel.com/content/www/us/en/docs/programmable/683337/22-4/dsp-builder-menu-options.html
Thank you
Kshitij Goel
0 포인트
RubenPadial
새로운 기여자 I
2,148 조회수
I meant that DSP Builder library is not displayed in Simulink Library Browser:
Is Matlab R2015a compatible with DSP Builder 22.4? Apparently it should be compatible according to DSP Builder Installing wizard.
After executing "DSP Builder - Start in MATLAB R2015a" (or "DSP Builder - Start in MATLAB R2022a") Matlab path is changed to "C:\intelFPGA_pro\22.4\quartus\dsp_builder". However, this directory is empty. All simulink files seem to be in "C:\intelFPGA_pro\22.4\quartus\dsbab". According to the thread https://community.intel.com/t5/FPGA-Intellectual-Property/DSP-Builder-Installation-Problem/m-p/69978, dsp_builder path should include BlockInfo.dll. Could this be the problem?
0 포인트
Kshitij_Intel
직원
2,122 조회수
It is not compatible. For more info on system requirements please refer below link.
https://www.intel.com/content/www/us/en/docs/programmable/683697/19-3/system-requirements.html
Please install the compatible version.
Thank you
Kshitij Goel
0 포인트
RubenPadial
새로운 기여자 I
2,117 조회수
I was aware of that information but I believed that table is outdated. There is no information about DSP Builder compatibility above v19.3. Is compatibility information for DSP Builder 22.4 available?
0 포인트
Kshitij_Intel
직원
2,070 조회수
Please find the supported MATLAB version compatibility list with Quartus in the below link.
https://www.intel.com/content/www/us/en/docs/programmable/683322/22-4/system-requirements.html
Thank you
Kshitij Goel
0 포인트
Kshitij_Intel
직원
2,041 조회수
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
0 포인트
RubenPadial
새로운 기여자 I
2,030 조회수
Is there any difference Matlab version compatibility  between Quartus and DSP builder?
Issue was solved using DSP Builder 17.1 and Matlab R2015a. DSP Bulder v22.4 and Matlab R2022a compatibility was not tested again. In addition installation wizard information is confusing because it specifies that DSP Builder 22.4 is compatible with Matlab R2013b or above.
0 포인트
응답
