Hello
Welcome to INTEL forum. Could provide again your license .dat file and your machine NICID for checking? And you can also reply/attach your file in private message.
Attached is the License.dat file generated by the Self Licensing Center and here is the result of an ‘ipconfig /all’ command:
C:\Users\admin>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : NLEWISW10CORP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-LM
Physical Address. . . . . . . . . : 18-66-DA-1F-FB-72
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e048:809a:e77c:ef64%14(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.1.179(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, May 29, 2019 8:13:02 AM
Lease Expires . . . . . . . . . . : Thursday, May 30, 2019 8:13:02 AM
Default Gateway . . . . . . . . . : 10.0.1.1
DHCP Server . . . . . . . . . . . : 10.0.1.1
DHCPv6 IAID . . . . . . . . . . . : 353920730
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-1E-D7-6B-18-66-DA-1F-FB-72
DNS Servers . . . . . . . . . . . : 68.94.156.1
68.94.157.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Hi Sir
Thanks for your update. But we do not received your attachment. Could you help to reattach again.
