Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1343 Discussions
USB Blaster Not Found In Quartus Prime
MMCC
I am having an issue where Quartus Prime is not detecting the USB Blaster device.  I have installed the drivers which came with Quartus Prime, the device is recognised in Device Manager and is working properly.
Versions of software and hardware:
Win 11 23H2
Quartus Prime version 23.1std. 0 Build 991 11/28/2023 SC Lite Edition
Altera USB Blaster Rev C
EPM240T100C5N Development board
I have tried the following:
1.  Complete reinstall of Quartus Prime
2.  Running as admin
3.  Running in safe mode and disabling the Altera JTAG Server
None of the above has worked.  Any further ideas or tests?
Farabi
May I know which one you are using- USB Blaster or USB Blaster II ?
regards,
Farabi
MMCC
USB Blaster.  I have ordered a new device to rule out the one I have.  Should be here in a few days.
NurAiman_M_Intel
Here are a few steps that you can try:
  1. Disconnect other USB device
  2. uninstall and reinstall the usb blaster driver
  3. You can also try this https://www.intel.com/content/www/us/en/support/programmable/articles/000073673.html
  4. If you have another USB Blaster, please try using another one and see if it works.
Aiman
MMCC
I have already tried these steps, except for Number 4.  I'm waiting for a new USB Blaster to arrive.
NurAiman_M_Intel
Let me know the update once you have try with new USB blaster.
Aiman
MMCC
I have the new Altera USB Blaster, from a different supplier, but its behaving like the first one.  It registers fine with device manager however is not available as a hardware choice in Quartus Prime programmer.
FvM
are we talking about an original Altera/Intel/Terasic download cable or a clone that is illegally using the brand name? In the latter case, I won't be sure if the device is fully functional.
Regarding enumeration device manager, what kind of device is displayed?
MMCC
I don't know, I bought them off eBay.  They say Altera on them.  Pictured here:
https://m.media-amazon.com/images/I/41bP044KZVL._AC_UF1000,1000_QL80_.jpg
Device manager says 'Altera USB Blaster' under the 'USB controllers' section and there are no errors.
The problem seems to be Quartus Programmer, it won't list the hardware.
NurAiman_M_Intel
Intel devices can only be purchase through Intel authorized distributor.
https://www.intel.com/content/www/us/en/partner/showcase/partner-directory/distributor.html#sort=relevancy
We do not ensure the device quality and functionality and also we do not provide further service if it is not originally from Intel.
Aiman
FvM
Thanks for confirming that you are not using genuine USB Blaster. According to this recent thread, USB Blaster clones are not guaranteed to work with Windows 10 driver. https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-Lite-does-not-recogize-the-USB-Blaster/td-p/1576328
