Community
cancel
Showing results for
Search instead for
Did you mean:
EBoln
Ubuntu usb blaster
I have: Quartus Std 18.1.1 and Quartus Std 20.1 on Windows 10, 11 and Ubuntu 18.04 and 20.04
Everything works on Windows, but on Ubuntu none of the options.
There is a project, build on all systems, but in Ubuntu i program sof into FPGA, FPGA or go to reset, or clean or work. SignalTap just not working in Ubuntu, i try many manuals from internet... of course first manual - official guide. Help pls.
upd:
I try Vmware with ubuntu+quartus 20.1 result is the same.
YuanLi_S_Intel
Hi, just wan to confirm with you. You are able to program SOF but not the usage of signal tap?
EBoln
Yes, if i using Programmer - all work, but if i using SignalTap and flash sof from gui - don't work, if i flash from Programmer and Run Analysis or just open SignalTap - FPGA go to reset...
NurinaW
Do you receive any error messages when you try to launch SignalTap?
Nurina
EBoln
Yes: instance not found, but sof not programmed....
NurinaW
Here's an old thread with a similar problem: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Signal-Tap-Instance-not-found/td-p/12932...
Could you try following the steps done and let me know if it helped?
Nurina
EBoln
I tried to sew the same file from windows that from linux
I would say that this topic is similar, but there is no solution:
https://community.intel.com/t5/Intel-Quartus-Prime-Software/SignalTap-working-on-Windows-but-not-on-...
NurinaW
Thanks for the feedback. Can you provide a screenshot of the error you see?
EBoln
unfortunately only tomorrow ...
NurinaW
That's alright, we can wait till then.
EBoln
Info (209060): Started Programmer operation at Fri Aug 13 07:09:28 2021
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F20DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Aug 13 07:09:29 2021
Error (261005): Can't find the instance. Download a design with SRAM Object File containing this instance.
I have programmed a sof file (same as in windows) when trying to access signaltap instances I got the following errors in the console. The FPGA itself was not programmed, I have a simple blinking LED implemented there (the names of the signaltap instances do not correspond to the content)
EBoln
on those rare times when the FPGA is programmed, when I try to run signaltap, I get the following:
Error (12852): Data integrity error is detected during JTAG communication.  The Signal Tap result is not trustworthy.  Please check the JTAG chain.
Error (261003): Can't continue the established JTAG communication.  Reconnect communications cable and device.
NurinaW
Did you install the libraries stated in Table 1 of this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf#...
Nurina
EBoln
NurinaW
Thanks, and you are using USB Blaster right? Not USB Blaster II? Can you let me know which device you are using?
Nurina
EBoln
Yes, USB Blaster, not USB Blaster II
NurinaW
Thank you for clarifying. Can you let me know which FPGA device you're using?
Nurina
EBoln
Cyclone IV, Cyclone V, Cyclone 10LP, Arria V, Max 10
NurinaW
Can you provide your .qar file? To generate this, go to Project->Archive Project.
EBoln
NurinaW
Thanks, reported your problem to our internal team. I will let you know what they come back with.
Nurina
