I have: Quartus Std 18.1.1 and Quartus Std 20.1 on Windows 10, 11 and Ubuntu 18.04 and 20.04
Everything works on Windows, but on Ubuntu none of the options.
There is a project, build on all systems, but in Ubuntu i program sof into FPGA, FPGA or go to reset, or clean or work. SignalTap just not working in Ubuntu, i try many manuals from internet... of course first manual - official guide. Help pls.
upd:
I try Vmware with ubuntu+quartus 20.1 result is the same.
Hi, just wan to confirm with you. You are able to program SOF but not the usage of signal tap?
Yes, if i using Programmer - all work, but if i using SignalTap and flash sof from gui - don't work, if i flash from Programmer and Run Analysis or just open SignalTap - FPGA go to reset...
Do you receive any error messages when you try to launch SignalTap?
Nurina
Here's an old thread with a similar problem: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Signal-Tap-Instance-not-found/td-p/1293277
Could you try following the steps done and let me know if it helped?
Nurina
I tried to sew the same file from windows that from linux
I would say that this topic is similar, but there is no solution:
Thanks for the feedback. Can you provide a screenshot of the error you see?
Info (209060): Started Programmer operation at Fri Aug 13 07:09:28 2021
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F20DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Aug 13 07:09:29 2021
Error (261005): Can't find the instance. Download a design with SRAM Object File containing this instance.
I have programmed a sof file (same as in windows) when trying to access signaltap instances I got the following errors in the console. The FPGA itself was not programmed, I have a simple blinking LED implemented there (the names of the signaltap instances do not correspond to the content)
on those rare times when the FPGA is programmed, when I try to run signaltap, I get the following:
Error (12852): Data integrity error is detected during JTAG communication. The Signal Tap result is not trustworthy. Please check the JTAG chain.
Error (261003): Can't continue the established JTAG communication. Reconnect communications cable and device.
Did you install the libraries stated in Table 1 of this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf#page=6
Nurina
Thanks, and you are using USB Blaster right? Not USB Blaster II? Can you let me know which device you are using?
Nurina
Thank you for clarifying. Can you let me know which FPGA device you're using?
Nurina
Can you provide your .qar file? To generate this, go to Project->Archive Project.
Thanks, reported your problem to our internal team. I will let you know what they come back with.
Nurina
