Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1092 Discussions
in 20.1 synthesis embedded pragma support for vhdl --synthesis library xxx appears to have been removed or is it part of the licensed versions now ?
CStra20
free edition targeting cyclone 10 GX in 20.1 the embedded pragma --synthesis library xxx is not working.
SyafieqS
Hi Chris,
What do you mean by not working? Is there any possible error message(s) and snapshots you could provide?
Refer to link below for VHDL Synthesis Attributes and Directives
https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/hdl/vhdl/vhdl_file_dir.htm
CStra20
See below the output. First line of bsv_pkg.vhd is the embedded pragma --synthesis library bsv
This pragma works in previous version of quartus.
Info: *******************************************************************
Info: Running Quartus Prime Synthesis
  Info: Version 20.1.0 Build 177 04/06/2020 SC Pro Edition
  Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
  Info: Your use of Intel Corporation's design tools, logic functions
  Info: and other software and tools, and any partner logic
  Info: functions, and any output files from any of the foregoing
  Info: (including device programming or simulation files), and any
  Info: associated documentation or information are expressly subject
  Info: to the terms and conditions of the Intel Program License
  Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
  Info: the Intel FPGA IP License Agreement, or other applicable license
  Info: agreement, including, without limitation, that your use is for
  Info: the sole purpose of programming logic devices manufactured by
  Info: Intel and sold by Intel or its authorized distributors. Please
  Info: refer to the applicable agreement for further details, at
  Info: https://fpgasoftware.intel.com/eula.
  Info: Processing started: Mon Jun 8 14:29:22 2020
  Info: System process ID: 217156
Info: Command: quartus_syn --64bit --analysis_and_elaboration --write_settings_files=off onewire
Info: Using INI file /home/chris/opencpi_clean/projects/core/hdl/primitives/ocpi/target-cyclone/quartus.ini
Info: qis_default_flow_script.tcl version: #2
Info: Initializing Synthesis...
Info: Project = "onewire"
Info: Revision = "onewire"
Info: Analyzing source files
Error (17816): VHDL error at bsv_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 1
Error (13827): Ignored construct bsv at bsv_pkg.vhd(161) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 161
Error (17816): VHDL error at fixed_float_types_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 1
Error (13827): Ignored construct fixed_float_types at fixed_float_types_pkg.vhd(35) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 35
