free edition targeting cyclone 10 GX in 20.1 the embedded pragma --synthesis library xxx is not working.
Hi Chris,
What do you mean by not working? Is there any possible error message(s) and snapshots you could provide?
Refer to link below for VHDL Synthesis Attributes and Directives
https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/hdl/vhdl/vhdl_f...
See below the output. First line of bsv_pkg.vhd is the embedded pragma --synthesis library bsv
This pragma works in previous version of quartus.
Info: *******************************************************************
Info: Running Quartus Prime Synthesis
Info: Version 20.1.0 Build 177 04/06/2020 SC Pro Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Mon Jun 8 14:29:22 2020
Info: System process ID: 217156
Info: Command: quartus_syn --64bit --analysis_and_elaboration --write_settings_files=off onewire
Info: Using INI file /home/chris/opencpi_clean/projects/core/hdl/primitives/ocpi/target-cyclone/quartus.ini
Info: qis_default_flow_script.tcl version: #2
Info: Initializing Synthesis...
Info: Project = "onewire"
Info: Revision = "onewire"
Info: Analyzing source files
Error (17816): VHDL error at bsv_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 1
Error (13827): Ignored construct bsv at bsv_pkg.vhd(161) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 161
Error (17816): VHDL error at fixed_float_types_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 1
Error (13827): Ignored construct fixed_float_types at fixed_float_types_pkg.vhd(35) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 35
