Hi All,
I am using Quatuts standard 22.4 version tool for code generation and wile iam trying to simulate generated code using Questasim observed below error.
# -- Loading package STANDARD
# ** Error:
Altera/Arria_10/unspecified/F200/synth/alterafpf_mul_double.vhd(6):
(vcom-1598) Library "altera_fp_functions_1914" not found.
Could any one share your thoughts for causing this error .
Nagapavani
Happens if simulation IP hasn't been generated or was generated for a different IP version.
You can regenerate the IP and rerun the simulation. Give it a try and see if that resolve the issue.
May I know if there is any update?
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer, kudos and rate 5/5 survey.
