Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
ADV7181B and Clocked input megacore function
Hello
could somebody help me?
I need to interface the adv7181B (with an YCbCr 4:2:2) with the Clocked Video Input function, but I have no idea about the settings I have to use.
I think that i need to load the PAL presets, but the output from the adv is 8bit wide, the CVI needs 10bit. I've tried to put the V_sync and H_sync on the same bus, but it doesn't seem to work.
Any hint, please?
Currently, I set CVI as 8 bit and embedded sync format.
I've set vid_datavalid as vcc, but all that i get is onle a black screen.
So, i've tryed to set CVI as 8 bit and separate sync format, but still, using vid_datavalid as vcc it does't work.
Output from the video conerter, in 4:2:2 YCbCr there are only
TD_DATA[7..0]
TD_HS
TD_VS
TD_RESET
TD_CLOCK (@27MHz)
I REALLY don't know how to interface them correctly with the CVI.
Any hint wold be precious..
..............up.............
I think "Vid_datavalid" should be conncet to a pin that is low level when Vertical Blanking Interval,and hight when signal is valid.Just like PIN "RTS" in SAA7113.
oh, thanls for your reply.
Right now, I "resolved" that problem long time ago!
@Phate,
May I ask how you have solved this problem? When I use the Test Pattern Generator (YCbCr, 8 bit, 4:2:2, Interlaced, Sequential) I get a correct image on the screen, so all the components between the generator and the VCO are correct. When I attach the TV Decoder, i just get a black (or grey) image, with a correct sync on the screen (well, most of the times).
I use the following signals with embedded sync signals:
TD_CLK
TD_DATA
TD_RESET
vid_locked and vid_datavalid are tied to VCC. Is this correct?
Any help would be appreciated!
right now, I don't remember how I did; there should be a couple of posts in this forum where other users helped me. If I find them, I link them.
Anyway, I should have sources at home.
Phate.
Hi Phate,
Thnx for your reply. I switched to the University Program cores, they just do the job perfect.
hi, phate ,how di you solve this?can you help me?
