Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Ask for help with Altera Monitor Program
​hello every body,
iam working on the tutorial: introduction to altera Qsys tool, and using the
Altera monitor program with DE0 to download the programm into the board, but
i obtain these errors after compile and load action:
Possible causes for the SREC verification failure:
1. Not enough memory in your Nios II system to contain the SREC file.
2. The locations in your SREC file do not correspond to a memory device.
3. You may need a properly configured PLL to access the SDRAM or Flash
memory.
So can any one help me please
thax
DE0-Nano, DE0-Nano-SoC, or just DE0?
In Qsys, how large did you make your on-chip-memory (I believe default is 4096 bytes)?
Did you use the simple program given in the tutorial, or a more complex one? If you did
not change the defaults, you will have a small amount of memory to load your program, and it may not fit in memory (Item 1 in the list).
Did you ensure that the base address of your on chip memory is 0x00? If did not lock the on-chip memory to that base address (In Qsys) and then
selected assign base addresses, the base for the on-chip memory will likely not be 0x00.
