Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1175 Discussions
Audio Codec using IC2
I need to project a interface to use the audio codec by using state machines to control it.
I am with a big difficulty in founding which address i should use in this protocol to conect with the microfone.
Can someone tell me wich address i should use?
Thanks!:)
Could you please provide more information about the target board and or devices you use for your project ?
Do you use a dev kit or a custom board ?
What device is IC2 ?
I use the standard kit.
I made a mistake in the name of the protocol
The real protocol that should be used is I2C.
What standard kit?
The I2C address should be in it's documentation though..
(at this rate, you're going to take a long time to get an answer...)
It is altera DE2.
See? That helps a lot.
The address is 0011010
Thx a lot! :)
