Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1147 Discussions
Avalon interface for FIR filter
Hi, my project is to design a 5-tap FIR filter. i have already completed the control unit,datapath unit, and also combined them. Now my task is to design an avalon interface for it.
The problem is i dont know what should i do, and what is the need for the avalon interface :confused:
Here i attached my codes, i really need some help in order to proceed...........
https://www.alteraforum.com/forum/attachment.php?attachmentid=6553 https://www.alteraforum.com/forum/attachment.php?attachmentid=6554 https://www.alteraforum.com/forum/attachment.php?attachmentid=6555
Well I don't know either. You are suggesting that then asking us why you want to...
Anyway from FIR perspective I assume an avalon IF will help to update coeffs if that is a requirement or to send input/receive output.
So choose your task.
does all the input and output for the cu/du top level need to be interfaced with the avalon IF? And what are things i need to write inside the verilog code? Thanks....
