Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Char Buffer UP IP
Hi
I'm trying to realize a text terminal on VGA display using Char buffer and VGA control available in UP IP v9.0
I've implemented the Nios on a DE1 board.
I'm sure that the hardware works properly, since writing a value directly on the mem position, a char appear on the VGA monitor
But I've some problem to write a suitable software.
I tried with:
int
main() {
int i;
alt_up_char_buffer_dev * my_ch_buf;
printf( "Nios II Alive!\n\n" );
my_ch_buf = alt_up_char_buffer_open_dev( "/dev/character_buffer_0_avalon_char_buffer_slave");
if ( my_ch_buf == NULL)
alt_printf ("Error: could not open pixel buffer device \n");
else
alt_printf ("Opened pixel buffer device \n");
i = alt_up_char_buffer_draw(my_ch_buf , 'A', 30,30);
printf( "res=%d",i );
but the answer is :( "Error: could not open pixel buffer device": infact the function "alt_up_char_buffer_open_dev" does not open the device and so the subcessive function "alt_up_char_buffer_draw" is unable to write anything.
Any suggestion?
Is maybe available some C examples using this device ?
Thank you in advance
Stefano
OK, I solved the problem by myself:
The correct neme of the device was:
"/dev/character_buffer_0";
instead of
"/dev/character_buffer_0_avalon_char_buffer_slave";
Whoever it is not clear for me where the "name" of the device is assigned
i.e. where to find the correct name
in the first release I used the name found in "system.h" which was of course wrong.
