Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1230 Discussions
Cyclone II starter dev kit,DE1, Audio HELP!
Hi Everyone,
I'm using the DE1 FPGA board. I'm trying to pass a signal from the mic to the speaker using the UP IP. The zip file and related pdf can be found here: http://www.altera.com/education/univ/materials/ip-cores/unv-ip-cores.html
I was successful in putting this in the provided reference design.
:confused: Problem: The fifospace is always empty and cannot be enabled. This creates further problems b/c then the mic isn't reading into the ADC buffer.
We also need to write to the speakers.
Command used for mic: alt_up_audio_read_left_channel()
Command used for the speaker: alt_up_audio_write_left_channel
The problem appears not to be with the code.
If anyone can help me, that would be awesome! :D
Hi! I am having the same problem . Can you revert back with the solution you found .
