Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Error in compilation
AmiruAk
Error (12006): Node instance "25" instantiates undefined entity "lpm_mux0"
Error (12006): Node instance "28" instantiates undefined entity "buffer"
Error (12006): Node instance "29" instantiates undefined entity "shift"
Error (12006): Node instance "23" instantiates undefined entity "lpm_add_sub0"
I am using quartus II 13.0 sp1
ShengN_Intel
In the pop-up Megafunction panel, there'll be a note as below check image:
Make sure those bdf files are in the same directory with the project file (QPF).
Or specify the library path to those bdf files located folder by go to:
Assignments -> Settings -> Libraries
Tools -> Options... -> Libraries
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Any further update or concern?
Have your problem being resolved?
Sheng
