I only get to see SRAM controller and SSRAM controller.
They are located in the 18.1/ip/altera/university_program/Memory.
I also want to test altera_up_sd_card_avalon_interface. How can I change this. Tried to add the directory to the search directory, but this doesn't help.
The Altera University Program IP can only be instantiated through Platform Designer or Qsys.
Hi Johh,
You are right and that is also the place where I was looking.
I know all the files alre in teh right directory, but Platform Designer nor Qsys don't show the SD card ip.
May I know if you observed "University Program" inside the IP Catalog? Could you provide the screenshot of the Platform Designer or Qsys? May I know which Quartus version are you using?
Please use Quartus 17.1 to instantiate it as it has been removed from latest Quartus.
