Anyone try to interface DE2 board (TV video in) with 2.4GHz Wireless AV Camera Receiver and output display to VGA? I had tried the code that I attached but seem like it does't work for the camera receiver. For your information, the wireless camera receiver had 4 optional channel frequency(2.414GHz,2.432GHz,2.450GHz,2.468GHz). Some channel output blue screen and other channel output nothing(LEDR and LEDG does not turn on). The code work for my DVD player and I wonder is it possible to apply the code on my wireless AV camera receiver? If yes, can you provide me any useful material about how to use TV decoder, I really appreciate it. Thanks ! Here is the wireless camera and receiver specification: http://mobilemegamall.com/goods/2-4ghz-wireless-pinhole-color-camera-plus-4-channel-receiver-cctv-37... (http://mobilemegamall.com/goods/2-4ghz-wireless-pinhole-color-camera-plus-4-channel-receiver-cctv-37...) Best regard, TWKLink Copied
Hello, I have to use the RGB signals for another purpose, so i divide the demonstrator in two blocks, one that generate the RGB signals and other that put it in the VGA output.
I didnt change the code, but some vertical lines are appearing over the video. is this your problem also? Anyone knows why? did you try putting the camera in NTFS? Eze- Mark as New
can u suggest me which type of NTSC camera and 2.4GHz wireless camera receiver that i can use with the DE2-70 board?i want to buy the camera n the receiver but have no idea.
Hi sorry for the late reply..Here is the camera i used:
http://mobilemegamall.com/goods/2-4ghz-wireless-pinhole-color-camera-plus-4-channel-receiver-cctv-37... (http://mobilemegamall.com/goods/2-4ghz-wireless-pinhole-color-camera-plus-4-channel-receiver-cctv-37...) Best regard, TWK- Mark as New
can u teach me or send in detail how to connect, and izzit easy to do that?
and are you able to display though the VGA to LCD monitor???or to the TRDB-LTM????if got,can you zip all the file that modified in the DE2_70 TV demo here?
but the camera you use got 2 mode rite? NTFS/PAL...there got write in the specification d...
