Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1174 Discussions
MAX 10 LVDS serdes CDR
This is Doosoo Ha, senior engineer of Opticis.
I am designing a LVDS serdes system using two(2) of MAX 10 devices.
I plan to build LVDS serdes system as transmitting data with only one LVDS signal line.
The LVDS using in my system is "LVDS with embedded clock". In other words, a separate clock signal for LVDS deserialization is not transmitted. I set LVDS serialize as factor is ‘10’ and the data rate as ‘100Mbps’.
I confirmed LVDS output is normal when inputting K28.5 data to LVDS serialize block.
After that, I designed deserialize block to LVDS deserialize block but problem has occurred during its verification.
What it saying as a problem is that the clock was asynchronized during deserialization because it was designed with "without clock signal".
I would like to know if there is any way clock not being asynchronized when I use LVDS with embedded clock without transmitting a separate clock signal for LVDS deserialization.
Please assist me how I can solve this problem.
As far as I know, there's no ready-made software CDR IP available for MAX10 and similar devices. It's however possible to perform receiver clock synchronization utilizing the PLL dynamic phase shift feature.
Thankyou.
I will test it using the PLL dynamic shift feature.
hi
I tried PLL Dynamic shift feature on there but PLL Dynamic shift feature didn't work.
Can you provide me any example of PLL Dynamic shift code?
I can't disclose the design, only give a brief idea how it works. The data edges are compared with a shifted clock (180 degree in SDR design), depending on the comparison the PLL output phase is either shifted up or down.
