Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
ModelSim Error - Undefined Variables and Global Declarations are Illegal in Verilog 2001 Syntax
jnspk
Hello!
So I have defined two parameters, "START_ADDR" and "END_ADDR" in a verilog header file, called "audioparams.vh":
`ifndef AUDIO_PARAMS
`define AUDIO_PARAMS
parameter START_ADDR = 32'h0000AF30;
parameter END_ADDR = 32'h000700A0;
`endif
And I have included this header file in another Verilog file (called, Memory_Controller.v) in order to access these parameters from this Verilog file.
(An overview of what I have in Memory_Controller.v):
`include "audioparams.vh"
module Memory_Controller(
	input sysclock,
	input read_enable,
	//input [32:0] read_address,
	//input [7:0] input_data,
	output reg [7:0] output_data,
	output reg reading_on,
	output reg reading_finished,
	input sysreset
//internal register holding current address
reg [31:0] present_address = START_ADDR;
wire [7:0] output_wire;
reg donereading = 1'b0;
And note that in Memory_Controller.v, I have included the audioparams.vh file. The project compiles without error on Quartus. However, when I attempt to run this TCL script on Modelsim:
#set the working directory, where all compiled Verilog goes
vlib work
#compile all verilog modules in top level module, to working directory
vlog Memory_Controller.v
# load simulation using Memory_Controller as top level simulation module
vsim Memory_Controller audioparams.vh M10K_Memory.v
# log all signals and add some signals to waveform window
log {/*}
# add wave {/*} would add all items in top level simulation module
add wave {/*}
# create clock
force {sysclock} 0 0ns, 1 {5 ns} -r 10ns
#changes from 0 to 1 every 5 ns --> repeats every 10 ns
#turn on read enable --> read out audio samples
force {read_enable} 1;
run 500ns
(Where Memory_Controller.v is the top level module in the project)
When I attempt to run the TCL script above to generate a ModelSim simulation, I get these errors:
I am wondering why the terminal thinks that START_ADDR and END_ADDR are undefined variables even though the parameters are imported into this verilog file. I was also wondering if perhaps, only the top level module (i.e. Memory_Controller.v) is being compiled, instead of all the files in the project?
I am very lost and was wondering if I have made a dumb mistake somewhere that I did not notice LOL.
I appreciate your support, and please go easy on me. I am fairly new to ModelSim
FvM
you quoted the relevant error message in question title "no global parameters in Verilog". Seeing this error, why do you wonder about follow-ups? You can select SystemVerilog syntax for the respective modules, or use defined macros instead of parameters. Quartus apparently doesn't distinguish different Verilog revisions so strictly, or did you globally enable SV syntax in Quartus?
HubertG
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
Please be assured that we are doing everything we can to resolve this as quickly as possible. This will take some time, and we appreciate your patience and understanding during this period of time. Your case will be attended by AE soonest possible.
Thank you again for your patience and understanding, and we are committed to provide you with the best possible support.
