Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Need help with audio
I'm supposed to store incoming audio, and I found this code used working with the "meida computer". Exactely where is the incoming data stored? Here is the code:
A fragment of C code that uses the audio port is shown in Figure 28. The code checks to see when the depth of either
the left or right Read FIFO has exceeded 75% full, and then moves the data from these FIFOs into a memory buffer.
This code is part of a larger program that is distributed as part of the Altera Monitor Program. The source code can
be found under the heading sample programs, and is identified by the name Media.
volatile int * audio_ptr = (int *) 0x10003040; // audio port address
int fifospace, int buffer_index = 0;
int left_buffer[BUF_SIZE];
int right_buffer[BUF_SIZE];
fifospace = *(audio_ptr + 1); // read the audio port fifospace register
if ( (fifospace & 0x000000FF) > 96) // check RARC, for È 75% full
/* store data until the audio-in FIFO is empty or the memory buffer is full */
while ( (fifospace & 0x000000FF) && (buffer_index < BUF_SIZE) )
left_buffer[buffer_index] = *(audio_ptr + 2); //Leftdata
right_buffer[buffer_index] = *(audio_ptr + 3); //Rightdata
++buffer_index;
Obviously in left_buffer and right_buffer, which can be expected to exist in NIOS RAM space.
