Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
Output File is the same as the Input File Lite Edition 21.1
Nadavb
Hello
I have installed Rev 21.1 and when running simulation Output Input Files are the same.
In Rev 16.1 all good.
I would appreciate any help.
ShengN_Intel
Make sure you are using Max II device family and recompile again before creating vector waveform file (vwf). Should be able to see the output after making changes to device family.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Nadavb
Hello Sheng
With Max II recompile I get the same problem.
ShengN_Intel
Select Auto device selected by the Fitter in Target device window for MAX II family then recompile and recreate vwf file. Next run Timing Simulation in vwf. I think you are selecting MAX II device which is not supported for vwf. Below attached a sample file for your reference.
Sheng
Nadavb
