Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Problem with Printf
I ve written a simple C-program running on Nios with output on JTAG-Uart Console.
Why if the surce code is
int m;
m=9;
printf("%d",m);
everthing works perfectly while if the source code is modified in:
int m;
m=10;
printf("%d",m);
it does not work anymore ???
moreover
please note that this strange behaviour occours using Nios II(e),
while using Nios II(s) everithing works well.
Hi, telle us more information
for your 1st problem,
What did you get ? "9" on nios2-terminal instead of 10 ? if so, clean and rebuild your nios project.
Maybe the new soft was not correctly downloaded, did you get errors ?
For your 2nd problem,
When you chose Nios II/e (=economic version), do you regenerate the Qsys, recompile the design, redownload to FPGA, do you rebuild the BSP, do you recompile the soft ?
regards
Thank you for your answer
The code is exactly what I write !
If I ask "printf" to write a integer number (%d) with a single digit it works correctly,
otherwise (just changing the 9 in 10) the program restart from the begin in a infinite loop.
Actually I've similar problem also using the multiplier (*) operator: sometimes it work but with few marginal
changing in the code, the execution restart from the beginning in an infinite loop.
However I noticed that this problem is limited to the usage of Nios II-e, while just changing the processor to Nios II-s and with no other modification
both the "printf" and the "multiplier" works correctly.
Of course !
Could be stack overflow
