Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Problem with Simulation
Hello ev'body, I'm trying to use Quartus II for university, I have no problems with VHDL file compilation and creation of .vwf file, but when I try to make a simulation an error appear:
can't continue timing simulation because delay information for design is missing
what I should do to solve it? Could somebody help me?
Thanks a lot.
You must run either "classic timing" or "time quest" analizer. If you are beginner with Quartus II use "classic timing analizer tool"
or you can try going to Assignments => Settings => Simulator Settings and changing the Simulation mode from Timing (default) to Functional. then you don't need timing information.
im trying to do a project on liquid propulsion engine simulation. but im not sure which software would be the best for this purpose. i wud also like to create a gud graphical user interface.
I am not so knowledgeable about this matter. So i have to learn it. Thanks for the post.
taux pret auto (http://pret-auto.org)
