Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Question for DE2 board LEDs
Hi there~
I'm going to control one 7 segment (HEX0) and 8 LEDs on DE2 board using
Quartus2. But, I don't know how to make delay for each LED
First of all, of the 7 segment pins, I use 6 of them to make# 1 and# 2. I think
that it's pretty straightforward because when I press first push button, it will
show# 1, and second push button is pressed,# 2 will show up.
But 8 LEDs need to be delayed. As I said, I going to use two push button as
input signals and each button stands for kind of selection.
Ok! Here is a simple version. what I'm going to do is when I push first push
button, the 7 segment will show# 1, and 8 LEDs start to turn on from the
first LED to 8th LES at each second. Otherwise, when I press 2nd push
button, 7 segment will show# 2 and LEDs need to turn on from 2nd led, 3rd
led, 5th led, 6th led and 8 led.
USE IEEE.STD_LOGIC_1164.all;
ENTITY AutomatedCarWash Is
Port(
KEY0, KEY1 :IN STD_LOGIC;
LEDG0, LEDG1, LEDG2, LEDG3, LEDG4, LEDG5, LEDG6, LEDG7,
HEX00, HEX01, HEX02, HEX03, HEX04, HEX06 :OUT STD_LOGIC);
END AutomatedCarWash;
ARCHITECTURE LEDs of AutomatedCarWash Is
signal AND1, AND2, OR1: STD_LOGIC;
BEGIN
AND1 <= (KEY0 and (NOT KEY1)) after 1 NS;
AND2 <= (KEY1 and (NOT KEY0)) after 1 NS;
OR1 <= AND1 or AND2 after 1 NS;
LEDG0 <= OR1 after 1 NS;
LEDG1 <= OR1 after 1 NS;
LEDG2 <= OR1 after 2 NS;
LEDG3 <= OR1 after 3 NS;
LEDG4 <= OR1 after 4 NS;
LEDG5 <= OR1 after 5 NS;
LEDG6 <= OR1 after 6 NS;
LEDG7 <= OR1 after 7 NS;
END LEDs;
ARCHITECTURE SevenSegment of AutomatedCarWash Is
Signal AND3, AND4, AND5: STD_LOGIC;
BEGIN
AND3 <= NOT KEY0 and NOT KEY1 after 1 NS;
AND4 <= NOT KEY0 and KEY1 after 1 NS;
AND5 <= KEY0 and NOT KEY1 after 1 NS;
HEX00 <= AND5 after 1 NS;
HEX01 <= NOT AND3 after 1 NS;
HEX02 <= AND4 after 1 NS;
HEX03 <= AND5 after 1 NS;
HEX04 <= AND5 after 1 NS;
HEX06 <= AND5 after 1 NS;
END SevenSegment;
In my opinion the after statement is just for simulation purposes. So everything you put into your vhdl-code in this example will take place simultanious.
Try a different way to delay your code like usleep or built some kind of counter into the code, but this won't work like you try it right now. But sorry I haven't got a solution right away. Here is a link to an example, where I showed how to delay an led with a modulo-counter, but it is a block design just look into the attachment. http://www.alteraforum.com/forum/showpost.php?p=85568&postcount=6
Good luck!
