Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Storing value in a reg
input [11:0] stimulus;
reg val;
always @(posedge clk)
val <=# 1 |(stimulus);
what should be the value stored in the register val? Is it the same as saying val = val | stimulus? And does value always store the lower bit of the stimulus since val is just 1 bit but stimulus is 12 bits?
The use of the '|' operator in this case is referred to as a reduction operator. val will get the bitwise OR of all the bits in stimulus. So basically if any bit in stimulus is set, val will be a '1', otherwise, it will be '0';
It's the same as writing
val <= stimulus[11] | stimulus[10] | stimulus[9] ..... | stimulus[1] | stimulus[0];
only obviously signicantly shorter.
Jake
