I have a problem using the second Pixel Buffer. I'm using the SRAM at 0x0000000 for the first one and I have althoug configured the second one on this adress in the SOPC-Builder. Now I am manipulating the SRAM via some VHDL code, which I connect via the External Master to Avalon slave form the UP, which works fine. Now in NIOS I created an buffer, within SDRAM , and passed the adress to the VGA-Framebuffer as a the adress of the backbuffer, which also works fine, at least in the debug mode. But when I switch from first to second buffer, the adress in the VGA-Pixelbuffer switches correctly but on the screen nothing happens. What's kind of weird is that sometimes I only can see the Pixelbuffer stored in the SDRAM, but I can't find out how this happens The only way to restore is then to unplug the device from current. Although my alt_alarm functions don't seem to work might this be reason for my problem. Thanks a lot for your help Best wishesLink Copied
