Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1226 Discussions
University SD CARD IP reads nothing
I added the altera_up_avalon_sd_card_interface into nios system.The SD card can be detected, and the READ_BLOCK command can be executed but no data be written in SD_CARD_BUFFER.Following is the code:
device_reference = alt_up_sd_card_open_dev(SD_CARD_NAME);
if(device_reference == NULL) printf("SD Card was not found.\n");
if (device_reference != NULL)
fprintf(fp,"\n write_read from %x\n",SD_CARD_BASE);
for(i=0;i<512;i++)(*((volatile unsigned char *)SD_CARD_BUFFER(SD_CARD_BASE, i)))=i & 0xff;
for(i=0;i<512;i++)bb[i]=(*((volatile unsigned char *)SD_CARD_BUFFER(SD_CARD_BASE, i)));
for(i=0;i<64;i++)
fprintf(fp,"%2x,%2x,%2x,%2x,%2x,%2x,%2x,%2x\n",bb[8*i],bb[8*i+1],bb[8*i+2],bb[8*i+3],bb[8*i+4],bb[8*i+5],bb[8*i+6],bb[8*i+7]);
fprintf(fp,"write_read ok\n\n");
if (Read_Sector_Data(0, 0))
for(i=0;i<64;i++)
fprintf(fp,"read_sector ok\n\n");
Where Read_Sector_Data() coming from "altera_up_sd_card_avalon_interface.c" as following:
bool Read_Sector_Data(int sector_index, int partition_offset)
// This function reads a sector at the specified address on the SD Card.
bool result = false;
if (alt_up_sd_card_is_Present())
short int reg_state = 0xff;
/* Write data to the SD card if the current buffer is out of date. */
if (current_sector_modified)
if (Write_Sector_Data(current_sector_index, 0) == false)
return false;
/* Multiply sector offset by sector size to get the address. Sector size is 512. Also,
* the SD card reads data in 512 byte chunks, so the address must be a multiple of 512. */
*command_argument_register = (sector_index + partition_offset)*512;
*command_register = CMD_READ_BLOCK;
do {
reg_state = *aux_status_register;
} while ((reg_state & 0x04)!=0);
// Make sure the request did not time out.
if ((reg_state & 0x10) == 0)
result = true;
current_sector_modified = false;
current_sector_index = sector_index+partition_offset;
return result;
The strange thing is that the data in SD_CARD_BUFFER after READ_BLOCK were same as the data in SD_CARD_BUFFER before READ_BLOCK.
Looking for your help.
Thanks in advance.
