Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1231 Discussions
Up/down counter Quartus II UP2 board
Hi guys!!!
i'm new in altera forum, and in vhdl too.
i must to do this project in Quartus II with the support of UP 2 board:
design an up/down decimal counter that:
1. show the count in a two 7 segment display in the UP2 board;
2. we can select the initial number of the count by switchs;
3. pushing the button present in UP2 board the counter must invert the count.
Someone can help me???
I Thanks you advance..:D
Why don't you show us what you wrote until now so that we can give you some advice?
Use counter from LPM library. It has most of the functionality you ask for. You need to code a HEX-to-7-segment active low decoder.
before to show my vhdl code i thanks you for reply me :))))
this is my work until now:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
ENTITY counter IS
PORT(
clk : in BIT;
upordwn : in STD_LOGIC;
initial : in STD_LOGIC_VECTOR(7 DOWNTO 0);
count : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
LED_1 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
LED_2 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
LED_CENT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
end counter;
ARCHITECTURE prova OF counter IS
SIGNAL totalbit : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL up_four : STD_LOGIC_VECTOR(4 DOWNTO 0);
SIGNAL low_four : STD_LOGIC_VECTOR(4 DOWNTO 0);
BEGIN
PROCESS(clk)
--QUI DEVO INSERIRE IL VALORE INIZIALE
if(clk'EVENT AND clk='1') THEN
if (upordwn='1') THEN
totalbit <= totalbit+1;
else
totalbit <= totalbit-1;
end if;
end if;
END PROCESS;
low_four(0) <= totalbit(0);
low_four(1) <= totalbit(1);
low_four(2) <= totalbit(2);
low_four(3) <= totalbit(3);
up_four(0) <= totalbit(4);
up_four(1) <= totalbit(5);
up_four(2) <= totalbit(6);
up_four(3) <= totalbit(7);
WITH up_four SELECT
--abcdefg
LED_1 <= "00000011" WHEN "1111", -- 0
"10011111" WHEN "1110", -- 1
"00100101" WHEN "1101", -- 2
"00001101" WHEN "1100", -- 3
"10011001" WHEN "1011", -- 4
"01001001" WHEN "1010", -- 5
"01000001" WHEN "1001", -- 6
"00011111" WHEN "1000", -- 7
"00000001" WHEN "0111", -- 8
"00001001" WHEN "0110", -- 9
"00010001" WHEN "0101", -- A
"00000001" WHEN "0100", -- B
"01100011" WHEN "0011", -- C
"00000011" WHEN "0010", -- D
"01100001" WHEN "0001", -- E
"01110001" WHEN "0000", -- F
"00000011" WHEN OTHERS;
--Lower 4 bits
WITH low_four SELECT
--abcdefg
LED_2 <= "00000011" WHEN "1111", -- 0
count <= totalbit;
end prova;
I have two problems yet!
1. initialing a strart number for the count by 8 switches present in UP2 board;
2. show the result in decimal (not in hexadecimal format) in the 7segment display.
thanks again :D
You could include a reset signal input that would load the value from the initial input to the totalbits value.
You can design your process this way:
PROCESS (clk,reset) IF (reset='1') THEN -- initialization of signals and outputs ELSIF (clk'EVENT AND clk='1') THEN -- counting END IF; END PROCESS;
To change from hexadecimal to decimal you can use the arithmetic library and divisions by 10.
