Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1147 Discussions
Using Library Models tutorial question
masterboyle
I'm trying to follow the "Using Library Models" tutorial VHDL versions and I'm getting VHDL syntax errors trying to synthesize the code in the document.  I am just copying and pasting the code, and I thought I did it correctly.
Quartus version is 20.1 lite targeting a Terasic DE-0 Nano Dev Kit.
The errors are pointing to these lines:
BEGIN
PROCESS ( Reset, Clock )
BEGIN
IF (Reset = ’1’) THEN
Areg <= (OTHERS => ’0’) ;
Breg <= (OTHERS => ’0’) ;
Zreg <= (OTHERS => ’0’) ;
SelR <= ’0’ ;
AddSubR <= ’0’ ;
Overflow <= ’0’ ;
Error (10500): VHDL syntax error at addersubtractor.vhd(39) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(39) near text "€"; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(39) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(40) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(40) near text "€"; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(40) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(41) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(41) near text "€"; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(41) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(42) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(42) near text "€"; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(42) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(43) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(43) near text "€"; expecting ";"
Error (10500): VHDL syntax error at addersubtractor.vhd(43) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(44) near text €
Error (10500): VHDL syntax error at addersubtractor.vhd(44) near text "€"; expecting ";"
Error (10500): VHDL syntax error at addersubtractor.vhd(44) near text ™
Error (10500): VHDL syntax error at addersubtractor.vhd(45) near text €
SyafieqS
Hi Boyle,
The error indicate a syntax error near text €, fix you vhdl at line stated in the error message. Check your brackets. For every open bracket you should have a close one.
SyafieqS
Hi Brian,
Any update regarding this?
