I'm currently trying to use the VGA capabilities of the ALTERA DE2 board to display a red screen with VHDL. The resolution i'm using is 640x480. I've written a code for it but it doesn't work, the monitor displays that it doesn't recieve a signal. I've run the simulation and i can't find the problem. Is there anyone who has an idea what i'm doing wrong? Here is my code:LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY vga IS
PORT (CLOCK_50 : IN std_logic; --50Mhz clock
KEY : IN std_logic_vector(3 downto 0); --RESET
VGA_B: OUT std_logic_vector(9 downto 0);
VGA_R: OUT std_logic_vector(9 downto 0);
VGA_G: OUT std_logic_vector(9 downto 0);
VGA_CLK : OUT std_logic;
VGA_BLANK :OUT std_logic; --active low
VGA_SYNC : OUT std_logic;
VGA_HS : OUT std_logic;
VGA_VS : OUT std_logic);
END vga;
ARCHITECTURE vg OF vga IS
SIGNAL line_fin : std_logic; --variable to determine if a line has finished drawing
SIGNAL line_count : integer; --variable for counting the amount of lines drawn
SIGNAL frame_fin : std_logic; --variable to determine if a frame had finished drawing
SIGNAL CLOCK_25 : std_logic; --25Mhz clock
CONSTANT P1 : integer := 24; --Front porch (horizontal)
CONSTANT P2 : integer := 48; --Back porch (horizontal)
CONSTANT HSYNC_TIME : integer := 95; -- H_Sync pulse lenght
CONSTANT V1 : integer := 11250; --Front porch (vertical)
CONSTANT V2 : integer := 25500; --Back porch (vertical)
CONSTANT VSYNC_TIME : integer := 1600; -- V_Sync pulse lenght
BEGIN
VGA_SYNC<= '0';
pixel_draw : PROCESS(CLOCK_25,KEY(0)) --for drawing pixels and generating blank pulses
VARIABLE hcount : INTEGER := 0;
VARIABLE vcount : INTEGER := 0;
BEGIN
IF KEY(0)= '0' THEN
hcount := 0;
vcount := 0;
line_fin <= '0';
frame_fin <= '0';
line_count <= 0;
VGA_BLANK <= '1';
ELSIF rising_edge(CLOCK_25) THEN
IF line_count < 480 THEN
IF hcount < 640 THEN
VGA_R <= "1111111111";--send pixel information each clock_cycle
VGA_B <= "0000000000";
VGA_G <= "0000000000";
VGA_BLANK <= '1';
hcount := hcount+1;
line_fin <= '0';
ELSIF hcount = 640 THEN
line_fin <= '1'; --line finished, pulse line_fin and start blank pulse
hcount := hcount+1;
VGA_BLANK <= '0';
ELSIF hcount >640 and hcount <= 640+P1+HSYNC_TIME+P2 THEN
hcount := hcount+1;--keep blank pulse low for a set amount of time
line_fin <= '0';
VGA_BLANK <= '0';
ELSE
hcount := 1; --reset counters and increment line_counter
line_count <= line_count+1;
END IF;
ELSIF line_count = 480 THEN
IF vcount < 1 THEN --frame is finished; pulse frame_fin and initiate vertical blank pulse
vcount := vcount+1;
VGA_BLANK <= '0';
frame_fin <= '1';
ELSIF vcount >= 1 and vcount < V1+V2+VSYNC_TIME THEN
vcount := vcount+1; --keep blank pulse low for a set amount of time
frame_fin <= '0';
VGA_BLANK <= '0';
ELSE
vcount := 0; -- reset counters and line_counter
VGA_BLANK <= '1';
line_count <= 0;
END IF;
END IF;
END IF;
END PROCESS;
horizontal_synchronisation : PROCESS(CLOCK_25,KEY(0))
VARIABLE hsync_counter : INTEGER := 0;
VARIABLE hsync_started : INTEGER := 0;
BEGIN
IF KEY(0)= '0' THEN
VGA_HS <= '1';
hsync_counter := 0;
hsync_started := 0;
IF line_fin = '1' or hsync_started = 1 THEN
hsync_started:= 1;
IF hsync_counter <= P1 THEN
hsync_counter := hsync_counter+1;--hsync stays high during front porch
VGA_HS <= '1';
ELSIF hsync_counter >= P1-1 and hsync_counter <= HSYNC_TIME+P1 THEN
hsync_counter := hsync_counter+1;--hsync activated
VGA_HS <= '0';
ELSIF hsync_counter >= HSYNC_TIME+P1-1 and hsync_counter < HSYNC_TIME+P1+P2 THEN
hsync_counter := hsync_counter+1;--hsync stays high during back porch
VGA_HS <= '1';
ELSE
hsync_counter := 0;--reset variables and counters
VGA_HS <= '1';
hsync_started := 0;
END IF;
ELSE
VGA_HS <= '1';
END IF;
END IF;
END PROCESS;
vertical_synchronisation : PROCESS(CLOCK_25,KEY(0))
VARIABLE vsync_counter : INTEGER := 0;
VARIABLE vsync_started : INTEGER := 0;
BEGIN
IF KEY(0) = '0' THEN
VGA_VS <= '1';
vsync_counter := 0;
vsync_started := 0;
IF frame_fin = '1' or vsync_started = 1 THEN
vsync_started := 1;
IF vsync_counter < V1-1 THEN
vsync_counter := vsync_counter+1;
VGA_VS <= '1';
ELSIF vsync_counter >= V1-1 and vsync_counter < VSYNC_TIME+V1-1 THEN
VGA_VS <= '0';
ELSIF vsync_counter >= VSYNC_TIME+V1-1 and vsync_counter < VSYNC_TIME+V1+V2 THEN
VGA_VS <= '1';
ELSE
vsync_counter := 0;
VGA_VS <= '1';
vsync_started := 0;
END IF;
ELSE
VGA_VS <= '1';
END IF;
END IF;
END PROCESS;
vga_clk_gen : PROCESS(CLOCK_50,KEY(0))--devides 50MHz clock in 2, making it a 25MHz clock
VARIABLE count : INTEGER := 0;
BEGIN
IF KEY(0)= '0' THEN
CLOCK_25 <= '0';
VGA_CLK <= '0';
count := 0;
ELSIF rising_edge(CLOCK_50) THEN
IF count = 0 THEN
CLOCK_25 <= '1'; --1 period of 50MHz high
VGA_CLK <= '1';
count := 1;
ELSIF count = 1 THEN
CLOCK_25 <= '0'; --1 period of 50MHz low
VGA_CLK <= '0';
count := 0;
END IF;
END IF;
END PROCESS;
END vg;
Here is my testfile for modelsim: LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY vga_test IS
END vga_test;
ARCHITECTURE vgt OF vga_test IS
SIGNAL KEY : std_logic_vector(3 downto 0);
SIGNAL CLOCK_50 : std_logic := '0';
SIGNAL VGA_HS : std_logic;
SIGNAL VGA_R : std_logic_vector(9 downto 0);
SIGNAL VGA_G : std_logic_vector(9 downto 0);
SIGNAL VGA_B : std_logic_vector(9 downto 0);
SIGNAL VGA_BLANK : std_logic;
SIGNAL VGA_SYNC : std_logic;
SIGNAL finished : boolean := FALSE;
BEGIN
hs : ENTITY work.vga PORT MAP (
KEY => KEY,
CLOCK_50 => CLOCK_50,
VGA_R => VGA_R,
VGA_G => VGA_G,
VGA_B => VGA_B,
VGA_HS => VGA_HS,
VGA_BLANK => VGA_BLANK,
VGA_SYNC => VGA_SYNC
CLOCK_50 <= NOT CLOCK_50 AFTER 10 ns WHEN not finished;
PROCESS
BEGIN
KEY <= "0000";
KEY(0) <= '0';
WAIT FOR 100 ns;
KEY(0) <= '1';
WAIT FOR 50 ms;
finished <= true;
WAIT;
END PROCESS;
END vgt;
Thanks in advance, Roelof
Thanks for your reply. I did some timing analysis with my oscilloscope and i measured some frequency's. The timing is the same as in the document i was using: http://www.epanorama.net/documents/pc/vga_timing.html I also tried a old crt monitor, this doesn't work either. It displays that the singals are "out of range". Maybe the document is wrong? I'm going to try your verilog file now. Roelof- Mark as New
The verilog file works after a few changes, i'm trying to convert it to vhdl.
Roelof- Mark as New
Hello I work with the board DE2, i'm spanish but i study in france and i forgot my inglish so excuse my if i make one mistake. My proyect is the show a controls board of a car in a touch-screen LCD. I dont know how start. If you can helps me with the control vga i do the rest. Thanks.
Hi hencel,
I tried to make the vhdl code to work, but there is a tiny flaw in the code. When I checked my signals with an oscilloscope or with my simulation, it looked like it should work. After a while I decided to learn verilog because it is very hard to keep vhdl compact. Verilog might be a bit harder but if you can read it it's much more convenient (well-organized). If you only know VHDL you could try to alter my code in the first post, I only have a working verilog driver. There are a lot of universities who use the de2 board, if you check their websites there are lots of examples how to use VGA in both verilog and VHDL. If you dont know how VGA works, you could check: http://www.epanorama.net/documents/pc/vga_timing.html For the list of links of universities: http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=30 This link helped me a lot: http://www1.cs.columbia.edu/~sedwards/classes/2007/4840/video.pdf (http://www1.cs.columbia.edu/%7esedwards/classes/2007/4840/video.pdf) -Roelof- Mark as New
Merci beaucoup. Thanks you very much.:)
--- Quote Start --- I attached a working 640x480 driver for debug / comparison. If the timing is off the nicer LCD monitors will just reject the signal. It can be helpful to plug it into an older CRT to get more information about what went wrong. --- Quote End --- Should this code put anything out on the VGA or is it just a driver. Sorry im confused!?:confused:
Topic Options
