Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Verilog code for serial communication protocols without Nios II processor
snehalatha
hello sir!
can you share the Verilog codes for serial communication protocols without using Nois II processor in the Quartus prime lite application and along with pin assignments and output?
SyafieqS
There is no template Verilog for serial communication, we used IP that is integrated in Qsys, generated to HDL.
You can use that way.
snehalatha
Thanks for your replay!!!
Can we implement UART with Avalon mm interface without Nios II  or any other processors??
SyafieqS
Let me know if there is any update
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
