Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Why is the FPGA Monitor Program Editor (from the UPDS) disabled/not working?
PKoor
Freshly installed on Windows10 with Quartus Prime 18.1, the intel FPGA Monitor Program built-in Editor (and "Project Files") are disabled from the "Windows" menu (grayed-out). The symptoms are similar to other posts, e.g. "Altera monitor program text editor not appearing". What is wrong? Is it maybe a Java problem? When I first started the Monitor program, I got a Java firewall warning (but said "run anyway").
-- Paul.
EBERLAZARE_I_Intel
Hi Paul,
I apologize for the late response, as I just got the notification.
The editor will be disabled during the debug session, and re-enabled when the debug session is exited
The source level debugging feature of the Monitor Program is a beta feature in the current release. The feature can be enabled and disabled at any point by going to the Edit menu and selecting Edit > Enable Source Level Debugging, or Edit > Disable Source Level Debugging, depending on whether the feature is currently disabled or enabled respectively.
Regards.
EBERLAZARE_I_Intel
Do you have any follow up from your side?
