Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
autoboot of UP Linux image on DE1-SoC fails
GiuseppeScollo
I tried to load the Intel FPGA University Program Linux image on my DE1-SoC board, but it does not boot. More precisely, i did the following sequence of actions:
  • copied DE1-SoC_UP_Linux.img to a microSD card with dd,
  • connected my laptop to the board with the USB-miniUSB cable,
  • started PuTTY,
  • inserted the microSD card in the board slot,
  • powered up the board.
The startup sequence in the PuTTY terminal window was OK up to the point of booting, where I got the following:
U-Boot 2013.01.01 (Apr 25 2014 - 04:59:35)
CPU  : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C:  ready
DRAM: 1 GiB
MMC:  ALTERA DWMMC: 0
In:   serial
Out:  serial
Err:  serial
Net:  mii0
Hit any key to stop autoboot: 0
** Unrecognized filesystem type **
altera_load: Failed with error code -4
## Starting application at 0x3FF7D4F8 ...
## Application terminated, rc = 0x0
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SOCFPGA_CYCLONE5 #
I checked the SD card with fdisk -l, here is what it shows:
Disk /dev/mmcblk0: 5,8 GiB, 6241124352 bytes, 12189696 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x0005a3a8
Dispositivo   Avvio  Start    Fine Settori  Size Id Tipo
/dev/mmcblk0p1      2121728 3799447 1677720 819,2M b W95 FAT32
/dev/mmcblk0p2      3801088 12189695 8388608    4G 83 Linux
/dev/mmcblk0p3         2048    4095   2048    1M a2 sconosciuto
The last partition, of unknown filesystem type, is that of the MBR as I understand (because of the 0xa2 Id), where the preloader should be found, correct? Is there something wrong with this image? The tutorial shows how to initialize the SD card with Win32DiskImager, but my laptop only runs (Ubuntu 16.04) Linux. Maybe is this the source of the problem? Thanks in advance for any help.
GiuseppeScollo
Re: autoboot of UP Linux image on DE1-SoC fails
The problem is not due to writing the SD card with dd, that's OK. It rather seems to be a preloader problem, in this version of the UP Linux image. I found the previous Image build as of October 18, 2016, at https://xdevs.com/doc/ALTERA/Terasic_DE1SoC/DE1-SoC-UP-Linux.zip that boots successfully. A comparison of the U-Boot startup sequence output in the PuTTY terminal in this case, with that reported for the newer Image, may suggest something about the possible preloader problem with the latter:
I2C: ready
DRAM: 1 GiB
In:  serial
Out: serial
Err: serial
Net: mii0
reading uImage
4315040 bytes read in 385 ms (10.7 MiB/s)
reading socfpga.dtb
19147 bytes read in 7 ms (2.6 MiB/s)
reading soc_system.rbf
2316870 bytes read in 209 ms (10.6 MiB/s)
## starting application at 0x3FF7D4F8 ...
## Booting kernel from Legacy Image at 00007fc0 ...
The kernel startup runs fine, but the following output is perhaps relevant to the subject problem, since it relates to mounting the SD card:
[   2.270471] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[   2.281243] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[   2.308475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. opts: (null)
I wonder whether the preloader in the newest version fails because of inability to recognize the filesystem type (ext4) mounted in the Linux partition.
FawazJ_Altera
Hello, This is based on the linux kernel itself, during compilation, it would be selected to support ext2, 3 and 4. preloader have nothing to do with the ext format. Since preloader could reach you to u-boot, it should be fine. Are you able to boot the board now? Thanks
GiuseppeScollo
Thank you for your reply. I am able to boot the board with the October 18, 2016 UP Linux image, not with the latest image, viz. the one which is available on the Intel FPGA UP website. Therefore, I regret I cannot make use of the newer features such as the Python GUI example, nor the C4DE and PyDE libraries. As you may see from my first post, U-Boot doesn't get any kernel image after having not recognized filesystem types, with an altera_load fail with error code -4 (I don't know what this means). Is there anything I could do to fix this?
FawazJ_Altera
Would you please guide me to the link that you downloaded the non-working image?
GiuseppeScollo
Sure, thank you! Here are two links, for your convenience:
The archive contains two SD-card images, one with U-Boot to boot a baremetal system, the other for the Ubuntu/Linux system. The latter is the troublesome image. Thank you in advance for your help.
FawazJ_Altera
Thanks for your clarifications, I will test the images and let you know the feedback. Thanks
