Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
basic questions
Hi everyone,
I'm having trouble with the code I posted below. I'm trying to design an ALU and am having conceptual problems.
Seems like for the case when sel is "1000" I get errors saying I need to use :=
I'm actually very confused about the difference between <= and := . Could someone please explain the difference?
In any case neither <= or := works with my code it seems.
Furthermore could someone explain to me the difference between std_logic_vectors and signed/unsigned numbers?
Also for the case when sel is "0010" is it okay for me to make the following comparison:
unsigned(temp) > (2**WIDTH)-1
Thank you
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity alu_ns is
generic (
WIDTH : positive := 16
port (
input1 : in std_logic_vector(WIDTH-1 downto 0);
input2 : in std_logic_vector(WIDTH-1 downto 0);
sel : in std_logic_vector(3 downto 0);
output : out std_logic_vector(WIDTH-1 downto 0);
overflow : out std_logic
end alu_ns;
architecture alu_arch of alu_ns is
begin
process(input1, input2, sel)
variable temp : std_logic_vector(WIDTH-1 downto 0);
--variable temp_mult: signed(2*WIDTH-1 downto 0);
begin
overflow <= '0';
case sel is
when "0000" =>
temp := std_logic_vector(resize(unsigned(input1), width + 1)+resize(unsigned(input2), width + 1));
output <= temp(width downto 0);
overflow <= temp(WIDTH);
when "0001" =>
temp := std_logic_vector(signed(input1)-signed(input2));
when "0010" =>
temp := std_logic_vector(signed(input1)*signed(input2));
if (unsigned(temp) > (2**WIDTH)-1) then
overflow <= '1';
end if;
when "0011" =>
temp := std_logic_vector(input1 and input2);
when "0100" =>
temp := std_logic_vector(input1 or input2);
when "0101" =>
temp := std_logic_vector(input1 xor input2);
when "0110" =>
temp := std_logic_vector(input1 nor input2);
when "0111" =>
temp := std_logic_vector(not input1);
when "1000" =>
--temp <= input1 sll 1;
temp <= input1(WIDTH-2 downto 0) & "0";
when "1001" =>
temp := '0' & input1(WIDTH-1 downto 0);
when "1010" =>
temp := input1(width/2 downto 0) & input1(width-1 downto 0);
when "1011" =>
for i in 0 to WIDTH-1 loop
temp(i) := input1((width-1)-i);
end loop;
when others =>
temp := (others => '0');
end case;
output <= temp(width-1 downto 0);
end process;
end alu_arch;
<= is for assigning a signal
:= is for assigning a variable.
Signals and variables behave differently. Variables are assigned immediately whilst signals are assigned when a wait occurs or the process suspends. I highly recommend you dont use variables until you unstand the implications of their behaviour. There is nothing you need a variable for - you can do everything you need for synthesis with signals, and it wont give you odd behaviour.
Std_logic_vectors are intended to just represent a collection of bits. Unsigned/signed types are meant to represent unsigned/signed numbers.
