Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1175 Discussions
hello, how to read data in eclipse from a custom ip outputs?
rkaib
Ahmed_H_Intel1
please check the system.h header file. How do you define the IP output? if isn't there, you must add the definition.
rkaib
can you please explain more or give an example?
Ahmed_H_Intel1
In the platform Designer you defined your custom IP addresses, one of them for example is a control register and other is the IP memory. You should see these addresses in the system.h header file in Eclipse. You can simply point to these addresses and read/write.
Please let me know if you have any concern or need more support.
