Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
intel FPGA Monitor Program can't work
TrivenNTHU
I am a DE10-nano user. I am using Quartus prime lite 21.1, and I am working on an Intel FPGA monitor program tutorial.  In the project creation stage, an error message appears stating that "Error running 'make DETECT_DEVICES'. (java.io.IOException...) "(picture above).
It seems to download the hardware system associated with the project onto the FPGA board(tutorial crop. picture below). I am sure that the USB-Blaster cable is already recognized.
However, when I click YES, I wait a long time.
I don't know what I can do. Is there any HW/SW configuration I don't set?
Sincerely,
Triven
TrivenNTHU
I found the answer.
First, I saw the command, make, and I tried to install make.exe for windows.
However, it still doesn't work.
Then, I finally know how it is. I realize Quartus lite 21.1 needs WSL1.
The pdf, Intel FPGA Monitor Program Tutorial for ARM*, even do not mention WSL1.
please configure this one.
Sincerely,
Triven
Farabi
Can you program the FPGA with simple design using JTAG via USB Blaster II programming cable?
regards,
Farabi
TrivenNTHU
TrivenNTHU
@Farabi Hello,
Could you give me any suggestions to try?
Sincerely,
Triven
AqidAyman_Intel
Hello Triven,
I will check this issue with the internal team, and will get back to you once I got any new updates.
Aqid Ayman
AqidAyman_Intel
Hello Triven,
Just want your confirmation, other than the error message you provided in the first post, is there any other error seen in your side?
Aqid Ayman
TrivenNTHU
No,
Just the error message in the first post.
BTW, I was following the pdf, Intel FPGA Monitor Program Tutorial for ARM*.
Please help me
Sincerely,
Triven
TrivenNTHU
I found the answer.
Sincerely,
Triven
AqidAyman_Intel
Hello Triven,
I’m glad that you find the solution, I now transition this thread to community support. This will be a good reference for the future enhancement of this program.
Thank you.
