Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1231 Discussions
please help: UDP application for SSS DE2-115
HI all
I want to compare the nios 2 and the hardware execution for the UDP/ip stack
and I'm looking for UDP application instead of telnet application which is TCP/ip stack .
someone has already realize an UDP application for DE2-115 board ?
any idea or suggestions or tutorial would be helpful for me !
many thanks in advance
Wikipedia has here (https://en.wikipedia.org/wiki/bsd_socket) some example codes for servers and clients, both TCP and UDP.
thanks Daixiwen for your reply
I'm asking how tp adapt this UDP client to the SSS in DE2-115 board
and what kind of application I can do with udp in the FPGA I'm looking for a huge traffic
to compare it with the hardware implementation of UDP
the udp application in the software stack is not the aim of my project
that's why I'm looking for a ready application like the one provided by altera for the TCP/IP stack (telnet)
any help will be appreciated
You won't find any ready application, but the link I gave you should show you how you can modify the SSS example to use UDP instead of TCP for a software implementation.
If you also need a hardware implementation you can have a look at the udp offload example on the wiki. You will probably need to adapt it to your card, because IIRC it was initially designed for a Stratix board, and an old version of Quartus.
thanks for your reply !
any other suggestions would be appreciated
how about benchmarking?
