i tried to run pong game in fpga prototyping with vhdl examples book chapter 13 but i couldn't run that can you help me
not without knowing whats wrong.
i used codes in the book i want to write in the vga pau logo but i couldn't that
Please post the code you're trying to get working, and tell us the errors.
these are codes
library ieee; use ieee. std_logic_1164. all ; use ieee. numeric_std. all ; entity pong_graph_animate is port ( clk, reset : std_logic ; btn: std_logic_vector (1 downto 0 ) ; video_on: in std_logic; pixel_x , pixel_y : in std_logic_vector ( 9 downto 0) ; graph_rgb : out std_logic_vector (2 downto 0); hit:out std_logic; gra_still: in std_logic; miss: in std_logic; graph_on : in std_logic ) ; end pong_graph_animate ; architecture arch of pong_graph_animate is signal refr_tick : std_logic; --x , y c o o r d i n a t e s (0,0) to ( 639 , 479 ) signal pix_x,pix_y : unsigned ( 9 downto 0) ; constant MAX_X: integer :=640; constant MAX_Y: integer:=480; -- w a l l l e f t , r i g h t b o u n d a r y constant WALL_X_L : integer :=32 ; constant WALL_X_R: integer :=35; -- b a r l e f t , r i g h t b o u n d a r y constant BAR_X_L: integer :=600; constant BAR_X_R: integer :=603; --b a r t o p , b o t t o m b o u n d a r y signal bar_y_t , bar_y_b : unsigned ( 9 downto 0) ; constant BAR_Y_SIZE: integer :=72; -- reg t o t r a c k t o p b o u n d a r y ( x p o s i t i o n is f i x e d ) signal bar_y_reg , bar_y_next : unsigned ( 9 downto 0) ; -- b a r moving v e l o c i t y when a b u t t o n i s p r e s s e d constant BAR_V: integer:=4; -- s q u a r e b a l l constant BALL_SIZE: integer:=8; -- 8 -- b a l l l e f t , r i g h t b o u n d a r y signal ball_x_l, ball_x_r : unsigned ( 9 downto 0) ; -- b a l l t o p , b o t t o m b o u n d a r y signal ball_y_t , ball_y_b : unsigned (9 downto 0) ; -- reg t o t r a c k l e f t , t o p b o u n d a r y signal ball_x_reg , ball_x_next ,ball_vx_reg : unsigned ( 9 downto 0) ; signal ball_y_reg , ball_y_next ,ball_vy_reg : unsigned ( 9 downto 0) ; --reg t o t r a c k b a l l s p e e d signal x_delta_reg , x_delta_next : unsigned ( 9 downto 0 ) ; signal y_delta_reg , y_delta_next : unsigned ( 9 downto 0 ) ; -- b a l l v e l o c i t y c a n be p o s o r neg constant BALL_V_P : unsigned ( 9 downto 0 ) := to_unsigned ( 2,10) ; constant BALL_V_N: unsigned ( 9 downto 0) := unsigned ( to_signed (-2,10)); -- r o u n d b a l l i m a g e ROM type rom_type is array (0 to 7 ) of std_logic_vector ( 0 to 7 ) ; -- ROM d e f i n i t i o n constant BALL_ROM: rom_type := ( "00111100" , -- * * * * "01111110", -- * * * * * * "11111111", -- * * * * * * * * "11111111", -- * * * * * * * * "11111111", -- * * * * * * * * "11111111", -- * * * * * * * * "01111110", -- * * * * * * "00111100" --* * * * ) ; signal rom_addr , rom_col : unsigned ( 2 downto 0 ) ; signal rom_data : std_logic_vector ( 7 downto 0) ; signal rom_bit : std_logic ; -- o b j e c t o u t p u t s i g n a l s signal wall_on ,bar_on , sq_ball_on , rd_ball_on : std_logic ; signal wall_rgb,bar_rgb , ball_rgb : std_logic_vector ( 2 downto 0) ; begin -- r e g i s t e r s process ( clk , reset) begin if reset = '1' then bar_y_reg <= ( others => '0' ) ; ball_x_reg <= ( others => '0' ) ; ball_y_reg <= ( others => '0' ) ; x_delta_reg <= ( "0000000100" ) ; y_delta_reg <= ( "0000000100") ; elsif( clk'event and clk = '1' ) then bar_y_reg <= bar_y_next ; ball_x_reg <= ball_x_next ; ball_y_reg <= ball_y_next ; x_delta_reg <= x_delta_next ; y_delta_reg <= y_delta_next ; end if ; end process; pix_x <= unsigned ( pixel_x ) ; pix_y <= unsigned ( pixel_y ) ; refr_tick <= '1' when ( pix_y = 481 ) and (pix_x=0) else '0'; wall_on <='1' when (WALL_X_L <= pix_x ) and (pix_x<=WALL_X_R) else '0'; wall_rgb <= "001"; -- b l u e -- b o u n d a r y bar_y_t <= bar_y_reg ; bar_y_b <= bar_y_t + BAR_Y_SIZE - 1; -- p i x e l w i t h i n b a r bar_on <= '1' when (BAR_X_L<=pix_x) and (pix_x<=BAR_X_R) and (bar_y_t <= pix_y ) and ( pix_y <= bar_y_b ) else '0' ; -- b a r r g b o u t p u t bar_rgb <= "001" ; --green -- new b a r y - p o s i t i o n process ( bar_y_reg , bar_y_b , bar_y_t , refr_tick , btn) begin bar_y_next <= bar_y_reg ; -- no move if refr_tick = '1' then if btn (1) = '1' and bar_y_b<(MAX_Y-1-BAR_V) then bar_y_next <= bar_y_reg + BAR_V; -- move down elsif btn ( 0 ) = '1'and bar_y_t > BAR_V then bar_y_next <= bar_y_reg - BAR_V ; -- move up end if; end if; end process; -- s q u a r e b a l l -- b o u n d a r y ball_x_l <= ball_x_reg ; ball_y_t <= ball_y_reg ; ball_x_r <= ball_x_l + BALL_SIZE - 1; ball_y_b <= ball_y_t + BALL_SIZE - 1; -- p i x e l w i t h i n b a l l sq_ball_on <= '1' when ( ball_x_l <= pix_x ) and ( pix_x <= ball_x_r ) and ( ball_y_t <= pix_y ) and ( pix_y <= ball_y_b ) else '0' ; -- map c u r r e n t p i x e l l o c a t i o n t o ROM a d d r / c o l rom_addr <= pix_y(2 downto 0) - ball_y_t(2 downto 0 ) ; rom_col <= pix_x(2 downto 0 ) - ball_x_l(2 downto 0 ) ; rom_data <= BALL_ROM(to_integer(rom_addr)); rom_bit <= rom_data(to_integer(rom_col)); -- p i x e l w i t h i n b a l l rd_ball_on<='1'when (sq_ball_on='1') and (rom_bit='1') else '0' ; ball_rgb <= "100" ; -- red ball_x_next <= to_unsigned((MAX_X)/2,10) when gra_still='1' else ball_x_reg + ball_vx_reg when refr_tick='1' else ball_x_reg ; ball_y_next <= to_unsigned((MAX_Y)/2,10) when gra_still='1' else ball_y_reg + ball_vy_reg when refr_tick='1' else ball_y_reg ; process ( ball_vx_reg , ball_vy_reg , ball_y_t,ball_x_l, ball_x_r , ball_y_t,ball_y_b,bar_y_t,bar_y_b,gra_still,hit,miss) begin hit <= '0' ; miss <= '0' ; ball_vx_next <= ball_vx_reg; ball_vy_next <= ball_vy_reg; if gra_still= '1' then -- i n i t i a 1 v e 1 o c i t y ball_vx_next <= BALL_V_N; ball_vy_next <= BALL_V_P; elsif ball_y_t < 1 then ball_vy_next <= BALL_V_P; elsif ball_y_b > (MAX_Y-1) then -- r e a c h b o t t o m ball_vy_next <= BALL_V_N; elsif ball_x_1 <= WALL_X_R then -- r e a c h w a l l ball_vx_next <= BALL_V_P; -- b o u n c e b a c k elsif (BAR-X-L <=ball-x-r) and (ball-x-r <=BAR-X-R) and (bar_y_t<=ball_y_b) and (ball_y_t<=bar_y_b) then -- r e a c h x of r i g h t b a r , a h i t ball_vx_next <= BALL_V_N; -- b o u n c e b a c k hit <= '1'; elsif (ball_x_r>MAX_X) then --r e a c h r i g h t b o r d e r miss <= '1' ; -- a mi s s end if ; end process ; graph_on <= wall_on or bar_on or rd_ball_on; process(video_on,wall_on,bar_on,rd_ball_on, wall_rgb, bar_rgb, ball_rgb) begin if video_on='0' then graph_rgb <= "000" ; --blank else if wall_on = '1' then graph_rgb <= wall_rgb; elsif bar_on = '1' then graph_rgb<= bar_rgb ; elsif rd_ball_on = '1' then graph_rgb <= ball_rgb; else graph_rgb <= "110"; -- y e l l o w background end if ; end if ; end process ; end arch; errors can't write to interface object ''miss'' of mode IN interface object ''hit''of mode out cannot be read.change object mode to buffer i added the hit:out std_logic, gra_still: in std_logic, miss: in std_logic, graph_on : in std_logic error can be from this- Mark as New
I think your error is self explanitory.
You cannot write to an input port. You need to make it an output. Also, outputs cannot be read internally. Either make it a buffer (like it suggests) or use an internal signal.- Mark as New
--- Quote Start --- I think your error is self explanitory. You cannot write to an input port. You need to make it an output. Also, outputs cannot be read internally. Either make it a buffer (like it suggests) or use an internal signal. --- Quote End --- " I have tried to run the above code but and they are executing successfully , the problem that is not that how do I assign the pins, auto assigning the pin gives a wrong output and when using the DE1 pin assignment how do i change the name as there is discrepancy in naming system " https://www.alteraforum.com/forum/attachment.php?attachmentid=6640
Topic Options
