Hi everybody!!!!
I'm trying to write a txt.file using SD Card Ip from Altera. when i built my project no error, but when i RUN AS, my project isn't writen successfuly. Help me!!!!!!!!!!!!!!! give me some advised my code: # include <io.h># include <system.h># include <stdio.h># include "altera_up_sd_card_avalon_interface.h" char name[] =" vidu.txt"; // when you open file vidu.txt, you see " xinchaocacban" short int file_handle; bool create, hum ; //=================initial sd card connect================== alt_up_sd_card_dev *device_reference = NULL; int connected = 0; device_reference = alt_up_sd_card_open_dev("/dev/SD_Card_0"); if (device_reference != NULL) { if ((connected == 0) && (alt_up_sd_card_is_Present())) { printf("Card connected.\n"); if (alt_up_sd_card_is_FAT16()) { printf("FAT16 file system detected.\n"); } else { printf("Unknown file system.\n"); } connected = 1; } else if ((connected == 1) && (alt_up_sd_card_is_Present() == false)) { printf("Card disconnected.\n"); connected = 0; } } //===============ghi file text================ file_handle = alt_up_sd_card_fopen(name, create); if (file_handle == -1) printf("file could not be open.\n"); else if ((file_handle == -2)) printf("file be already.\n"); else printf("file be open.\n"); if (create == true) printf("file be create .\n"); for(j=0; j< 256; j++) { hum= alt_up_sd_card_write(file_handle,ag[j]); } if (hum == true) printf ("successful. \n"); alt_up_sd_card_fclose(file_handle); }Link Copied
you can try this code :
int main() { device_reference = alt_up_sd_card_open_dev("/dev/SD"); if (device_reference != NULL) { if ((connected == 0) && (alt_up_sd_card_is_Present())) { printf("Card connected.\n"); if (alt_up_sd_card_is_FAT16()) printf("FAT16 file system detected.\n"); else printf("Unknown file system.\n"); connected = 1; } else if ((connected == 1) && (alt_up_sd_card_is_Present() == false)) { printf("Card disconnected.\n"); connected = 0; } } //===============ghi file text================ file_handle = alt_up_sd_card_fopen(name, true); if (file_handle == -1) printf("file could not be open.\n"); else if ((file_handle == -2)) printf("file is already open.\n"); else printf("file be open.\n"); for(j=0; j< 24; j++) { hum= alt_up_sd_card_write(file_handle,ag[j]); } if (hum == true) printf ("successful. \n"); alt_up_sd_card_fclose(file_handle); return 0; }For more complete information about compiler optimizations, see our Optimization Notice.
