Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
write file .txt to sd card on DE2
Hi everybody!!!!
I'm trying to write a txt.file using SD Card Ip from Altera. when i built my project no error, but when i RUN AS, my project isn't writen successfuly.
Help me!!!!!!!!!!!!!!!
give me some advised
my code:
# include <io.h># include <system.h># include <stdio.h># include "altera_up_sd_card_avalon_interface.h"
char name[] =" vidu.txt"; // when you open file vidu.txt, you see " xinchaocacban"
short int file_handle;
bool create, hum ;
//=================initial sd card connect==================
alt_up_sd_card_dev *device_reference = NULL;
int connected = 0;
device_reference = alt_up_sd_card_open_dev("/dev/SD_Card_0");
if (device_reference != NULL)
if ((connected == 0) && (alt_up_sd_card_is_Present()))
printf("Card connected.\n");
if (alt_up_sd_card_is_FAT16())
printf("FAT16 file system detected.\n");
else
printf("Unknown file system.\n");
connected = 1;
else if ((connected == 1) && (alt_up_sd_card_is_Present() == false))
printf("Card disconnected.\n");
connected = 0;
//===============ghi file text================
file_handle = alt_up_sd_card_fopen(name, create);
if (file_handle == -1)
printf("file could not be open.\n");
else if ((file_handle == -2))
printf("file be already.\n");
else
printf("file be open.\n");
if (create == true)
printf("file be create .\n");
for(j=0; j< 256; j++)
hum= alt_up_sd_card_write(file_handle,ag[j]);
if (hum == true)
printf ("successful. \n");
alt_up_sd_card_fclose(file_handle);
you can try this code :
int main()
device_reference = alt_up_sd_card_open_dev("/dev/SD");
else
connected = 1;
connected = 0;
file_handle = alt_up_sd_card_fopen(name, true);
printf("file is already open.\n");
else
for(j=0; j< 24; j++)
if (hum == true)
return 0;
