Software Archive
Read-only legacy content
17061 Discussions
Intel Firmware Engine Software Development Kit now available
BrianRichardson
The Intel® Firmware Engine Software Development Kit (Intel® Firmware Engine SDK) Release 1.0 is now available for download. This SDK allows developers to build packages from existing Intel® UDK2014 code, allowing silicon component vendors and firmware developers to rapidly extend the Intel Firmware Engine ecosystem.
Note: Requires Intel® Firmware Engine Release 1.0.2 to be installed first.
See more at: https://firmware.intel.com/learn/intel-firmware-engine/downloads
yaswanth_k_
does working of sensors is possible in the version
BrianRichardson
You can use the Intel Firmware Engine SDK to create packages for sensors that require firmware initialization, or check with the sensor vendor to see if they have support (UEFI driver or Intel Firmware Engine package).
