0xC0000005 Access Violation Writing Location Error
emreka82
I am writing a code with large arrays. The code works fine for small matrices but when I go beyond a certain level, the following error pops out:
Unhandled exception at 0x77913560 in 3d.exe: 0xC0000005: Access violation writing location 0x0000000000050e14.
I am dynamically allocating memory with variables, then deallocating them. The code is very long, longer than 20,000 lines. I want to trace the problem. Before deciding to start this topic, I search the forum and other sources. The "Stack Size" problem has seemed reasonable. I changed reserve size to 200,000,000 and commit size 20,000,000. The problem stayed the same with small differences:
Unhandled exception at 0x77913560 in 3d.exe: 0xC0000005: Access violation writing location 0x00000000001e0e84.
As you can see the code given at the end of the error line is different, I want to know and trace the error. Any kind of help will be appreciated. Thanks !
Emre
Bernard
Valued Contributor I
Why I cannot see my posts?Two answers were made to emreka82 last post.
Bernard
This is the third attempt to post an answer ,previous two posts were not published.You need to setup the correct symbol path and later reproduce the unknown exception by issueing this command sxe "exception address" and after this press g .
emreka82
Firstly, I run Windbg as administrator. Then open the executable file:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
CommandLine: E:\3d\3d\3d\x64\Debug\3d.exe
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
ModLoad: 00000001`3f4c0000 00000001`3fc72000 3d.exe
ModLoad: 00000000`77780000 00000000`77929000 ntdll.dll
ModLoad: 00000000`770a0000 00000000`771bf000 C:\Windows\system32\kernel32.dll
ModLoad: 000007fe`fdc90000 000007fe`fdcfb000 C:\Windows\system32\KERNELBASE.dll
ModLoad: 000007fe`fe2a0000 000007fe`fe2b9000 C:\Windows\system32\imagehlp.dll
ModLoad: 000007fe`ff2f0000 000007fe`ff38f000 C:\Windows\system32\msvcrt.dll
ModLoad: 000007fe`fe350000 000007fe`fe42b000 C:\Windows\system32\ADVAPI32.dll
ModLoad: 000007fe`fe2c0000 000007fe`fe2df000 C:\Windows\SYSTEM32\sechost.dll
ModLoad: 000007fe`ff1c0000 000007fe`ff2ed000 C:\Windows\system32\RPCRT4.dll
(1a20.1620): Break instruction exception - code (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!CsrSetPriorityClass+0x40:
00000000`7782cb60 cc int 3
Then, I setup the correct symbol path using .symfix.
0:000> .symfix
If I am not wrong, the "exception adress" is 80000003.
0:000> sxe 80000003
Then, I press g and at the end of the execution of my program the output of Windbg is as follows:
0:000> g
(1220.a70): Stack overflow - code c00000fd (first chance)
First chance exceptions are reported before any exception handling.
This exception may be expected and handled.
3d!__chkstk+0x37:
00000001`40607027 41c60300 mov byte ptr [r11],0 ds:00000000`00143000=00
Here, the exception adress changes into c00000fd
0:000> sxe c00000fd
0:000> g
(1220.a70): Access violation - code c0000005 (first chance)
ntdll!RtlIsDosDeviceName_U+0x622b:
00000000`777dfcab e86030ffff call ntdll!RtlCompareMemoryUlong (00000000`777d2d10)
Then it changes into c0000005
0:000> sxe c0000005
0:000> g
(1220.a70): Access violation - code c0000005 (!!! second chance !!!)
and this procedure goes on, gives the same outputs:
0:000> sxe c0000005
0:000> g
0:000> sxe c0000005
0:000> g
0:000> sxe c0000005
0:000> g
Hopefully I don't misunderstand your directions. Now, what should I do ? Thanks.
Bernard
From I was able to understand the exception has occured 0x622b bytes inside ntdll.This function "RtlIsDosDeviceName_U" is used to decide if the device name is valid DOS name.Exception probably occures when RtlCompareMemoryUlong is executing.These Rtl routines are also used by the drivers.By inspecting RtlCompareMemoryUlong parameter which is a void pointer to block of memory I suspect that this pointer is pointing to uninitialized or PAGE_NOACCESS memory.
Can you post the full stack?Please issue kb command.
emreka82
Hi iliya,
Output after kd command:
ModLoad: 00000001`3f170000 00000001`3f922000 3d.exe
ModLoad: 00000000`77420000 00000000`775c9000 ntdll.dll
ModLoad: 00000000`770b0000 00000000`771cf000 C:\Windows\system32\kernel32.dll
ModLoad: 000007fe`fd930000 000007fe`fd99b000 C:\Windows\system32\KERNELBASE.dll
ModLoad: 000007fe`fe3e0000 000007fe`fe3f9000 C:\Windows\system32\imagehlp.dll
ModLoad: 000007fe`fe610000 000007fe`fe6af000 C:\Windows\system32\msvcrt.dll
ModLoad: 000007fe`fe050000 000007fe`fe12b000 C:\Windows\system32\ADVAPI32.dll
ModLoad: 000007fe`fdfd0000 000007fe`fdfef000 C:\Windows\SYSTEM32\sechost.dll
ModLoad: 000007fe`fdea0000 000007fe`fdfcd000 C:\Windows\system32\RPCRT4.dll
(1a84.1ac8): Break instruction exception - code 80000003 (first chance)
00000000`774ccb60 cc int 3
0:000> .symfix
0:000> sxe 0x622b
0:000> g
(1a84.1ac8): Stack overflow - code c00000fd (first chance)
3d!__chkstk+0x37:
00000001`3f7c6f77 41c60300 mov byte ptr [r11],0 ds:00000000`001b3000=00
0:000> kd
00000000`001b4bd0 715aab58
00000000`001b4bd4 00000000
00000000`001b4bd8 3f343077
00000000`001b4bdc 00000001
00000000`001b4be0 001b4c30
00000000`001b4be4 00000000
00000000`001b4be8 3f34326c
00000000`001b4bec 00000001
00000000`001b4bf0 00000000
00000000`001b4bf4 00000000
00000000`001b4bf8 00000000
00000000`001b4bfc 00000000
00000000`001b4c00 00000000
00000000`001b4c04 00000000
00000000`001b4c08 00000000
00000000`001b4c0c 00000000
00000000`001b4c10 00000000
00000000`001b4c14 00000000
00000000`001b4c18 00000000
00000000`001b4c1c 00000000
00000000`001b4c20 00000000
00000000`001b4c24 00000000
00000000`001b4c28 00000000
00000000`001b4c2c 00000000
00000000`001b4c30 00000001
00000000`001b4c34 00000000
00000000`001b4c38 00000000
00000000`001b4c3c 00000000
00000000`001b4c40 00000000
00000000`001b4c44 00000000
00000000`001b4c48 00000000
00000000`001b4c4c 00000000
00000000`001b4c50 00000000
00000000`001b4c54 00000000
00000000`001b4c58 00000000
00000000`001b4c5c 00000000
00000000`001b4c60 00000000
00000000`001b4c64 00000000
00000000`001b4c68 00000000
00000000`001b4c6c 00000000
00000000`001b4c70 00000000
00000000`001b4c74 00000000
00000000`001b4c78 00000000
00000000`001b4c7c 00000000
00000000`001b4c80 00000000
00000000`001b4c84 00000000
00000000`001b4c88 00000000
00000000`001b4c8c 00000000
00000000`001b4c90 00000000
00000000`001b4c94 00000000
00000000`001b4c98 00000000
00000000`001b4c9c 00000000
00000000`001b4ca0 00000000
00000000`001b4ca4 00000000
00000000`001b4ca8 00000000
00000000`001b4cac 00000000
00000000`001b4cb0 00000000
00000000`001b4cb4 00000000
00000000`001b4cb8 00000000
00000000`001b4cbc 00000000
00000000`001b4cc0 00000000
00000000`001b4cc4 00000000
00000000`001b4cc8 00000000
00000000`001b4ccc 00000000
00000000`001b4cd0 00000000
00000000`001b4cd4 00000000
00000000`001b4cd8 00000000
00000000`001b4cdc 00000000
00000000`001b4ce0 00000000
00000000`001b4ce4 00000000
00000000`001b4ce8 00000000
00000000`001b4cec 00000000
00000000`001b4cf0 00000000
00000000`001b4cf4 00000000
00000000`001b4cf8 00000000
00000000`001b4cfc 00000000
00000000`001b4d00 00000000
00000000`001b4d04 00000000
00000000`001b4d08 00000000
00000000`001b4d0c 00000000
00000000`001b4d10 00000000
00000000`001b4d14 00000000
00000000`001b4d18 00000000
00000000`001b4d1c 00000000
00000000`001b4d20 00000000
00000000`001b4d24 00000000
00000000`001b4d28 00000000
00000000`001b4d2c 00000000
00000000`001b4d30 00000000
00000000`001b4d34 00000000
00000000`001b4d38 00000000
00000000`001b4d3c 00000000
00000000`001b4d40 00000000
00000000`001b4d44 00000000
00000000`001b4d48 00000000
00000000`001b4d4c 00000000
00000000`001b4d50 00000000
00000000`001b4d54 00000000
00000000`001b4d58 00000000
00000000`001b4d5c 00000000
00000000`001b4d60 00000000
00000000`001b4d64 00000000
00000000`001b4d68 00000000
00000000`001b4d6c 00000000
00000000`001b4d70 00000000
00000000`001b4d74 00000000
00000000`001b4d78 00000000
00000000`001b4d7c 00000000
00000000`001b4d80 00000000
00000000`001b4d84 00000000
00000000`001b4d88 00000000
00000000`001b4d8c 00000000
00000000`001b4d90 00000000
00000000`001b4d94 00000000
00000000`001b4d98 00000000
00000000`001b4d9c 00000000
00000000`001b4da0 00000000
00000000`001b4da4 00000000
00000000`001b4da8 00000000
00000000`001b4dac 00000000
00000000`001b4db0 00000000
00000000`001b4db4 00000000
00000000`001b4db8 00000000
00000000`001b4dbc 00000000
00000000`001b4dc0 00000000
00000000`001b4dc4 00000000
00000000`001b4dc8 00000000
00000000`001b4dcc 00000000
00000000`001b4dd0 00000000
00000000`001b4dd4 00000000
00000000`001b4dd8 00000000
00000000`001b4ddc 00000000
00000000`001b4de0 00000000
00000000`001b4de4 00000000
00000000`001b4de8 00000000
00000000`001b4dec 00000000
00000000`001b4df0 00000000
00000000`001b4df4 00000000
00000000`001b4df8 00000000
00000000`001b4dfc 00000000
00000000`001b4e00 00000000
00000000`001b4e04 00000000
00000000`001b4e08 00000000
00000000`001b4e0c 00000000
00000000`001b4e10 00000000
00000000`001b4e14 00000000
00000000`001b4e18 00000000
00000000`001b4e1c 00000000
00000000`001b4e20 00000000
00000000`001b4e24 00000000
00000000`001b4e28 00000000
00000000`001b4e2c 00000000
00000000`001b4e30 00000000
00000000`001b4e34 00000000
00000000`001b4e38 00000000
00000000`001b4e3c 00000000
00000000`001b4e40 00000000
00000000`001b4e44 00000000
00000000`001b4e48 00000000
00000000`001b4e4c 00000000
00000000`001b4e50 00000000
00000000`001b4e54 00000000
00000000`001b4e58 00000000
00000000`001b4e5c 00000000
00000000`001b4e60 00000000
00000000`001b4e64 00000000
00000000`001b4e68 00000000
00000000`001b4e6c 00000000
00000000`001b4e70 00000000
00000000`001b4e74 00000000
00000000`001b4e78 00000000
00000000`001b4e7c 00000000
00000000`001b4e80 00000000
00000000`001b4e84 00000000
00000000`001b4e88 00000000
00000000`001b4e8c 00000000
00000000`001b4e90 00000000
00000000`001b4e94 00000000
00000000`001b4e98 00000000
00000000`001b4e9c 00000000
00000000`001b4ea0 00000000
00000000`001b4ea4 00000000
00000000`001b4ea8 00000000
00000000`001b4eac 00000000
00000000`001b4eb0 00000000
00000000`001b4eb4 00000000
00000000`001b4eb8 00000000
00000000`001b4ebc 00000000
00000000`001b4ec0 00000000
00000000`001b4ec4 00000000
00000000`001b4ec8 00000000
00000000`001b4ecc 00000000
00000000`001b4ed0 00000000
00000000`001b4ed4 00000000
00000000`001b4ed8 00000000
00000000`001b4edc 00000000
00000000`001b4ee0 00000000
00000000`001b4ee4 00000000
00000000`001b4ee8 00000000
00000000`001b4eec 00000000
00000000`001b4ef0 00000000
00000000`001b4ef4 00000000
00000000`001b4ef8 00000000
00000000`001b4efc 00000000
00000000`001b4f00 00000000
00000000`001b4f04 00000000
00000000`001b4f08 00000000
00000000`001b4f0c 00000000
00000000`001b4f10 00000000
00000000`001b4f14 00000000
00000000`001b4f18 00000000
00000000`001b4f1c 00000000
00000000`001b4f20 00000000
00000000`001b4f24 00000000
00000000`001b4f28 00000000
00000000`001b4f2c 00000000
00000000`001b4f30 00000000
00000000`001b4f34 00000000
00000000`001b4f38 00000000
00000000`001b4f3c 00000000
00000000`001b4f40 00000000
00000000`001b4f44 00000000
00000000`001b4f48 00000000
00000000`001b4f4c 00000000
00000000`001b4f50 00000000
00000000`001b4f54 00000000
00000000`001b4f58 00000000
00000000`001b4f5c 00000000
00000000`001b4f60 00000000
00000000`001b4f64 00000000
00000000`001b4f68 00000000
00000000`001b4f6c 00000000
00000000`001b4f70 00000000
00000000`001b4f74 00000000
00000000`001b4f78 00000000
00000000`001b4f7c 00000000
00000000`001b4f80 00000000
00000000`001b4f84 00000000
00000000`001b4f88 00000000
00000000`001b4f8c 00000000
00000000`001b4f90 00000000
00000000`001b4f94 00000000
00000000`001b4f98 00000000
00000000`001b4f9c 00000000
00000000`001b4fa0 00000000
00000000`001b4fa4 00000000
00000000`001b4fa8 00000000
00000000`001b4fac 00000000
00000000`001b4fb0 00000000
00000000`001b4fb4 00000000
00000000`001b4fb8 00000000
00000000`001b4fbc 00000000
00000000`001b4fc0 00000000
00000000`001b4fc4 00000000
00000000`001b4fc8 00000000
00000000`001b4fcc 00000000
Bernard
Please fix your symbol path.This is not call stack this is raw dump of call stack.I need to see the caller of RtlCompareMemoryUlong and more important the pointer which is passed to this function.
You can also use !analyze -v after this .ecxr and kb to display the ccall stack.
emreka82
Doesn't .symfix command  fix my symbol path ? Anyway, I apply your suggestions of the second paragraph:
0:000> !analyze -v
* Exception Analysis *
***** OS symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ntdll!_PEB ***
*** work. ***
*** Type referenced: nt!IMAGE_NT_HEADERS32 ***
FAULTING_IP:
ntdll!CsrSetPriorityClass+40
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 00000000774ccb60 (ntdll!CsrSetPriorityClass+0x0000000000000040)
ExceptionCode: 80000003 (Break instruction exception)
ExceptionFlags: 00000000
NumberParameters: 1
Parameter[0]: 0000000000000000
FAULTING_THREAD: 0000000000001614
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
PROCESS_NAME: 3d.exe
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: ntdll
FAULTING_MODULE: 0000000077420000 ntdll
DEBUG_FLR_IMAGE_TIMESTAMP: 4ec4aa8e
ERROR_CODE: (NTSTATUS) 0x80000003 - { ZEL DURUM} Kesme Noktas
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - Bir veya daha fazla ba ms z de i ken ge ersiz
EXCEPTION_PARAMETER1: 0000000000000000
APP: 3d.exe
PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS
BUGCHECK_STR: APPLICATION_FAULT_WRONG_SYMBOLS
LAST_CONTROL_TRANSFER: from 0000000077482ef5 to 00000000774ccb60
STACK_TEXT:
00000000`715ef160 00000000`77482ef5 : 00000000`00000000 00000000`77525468 00000000`00000000 00000000`00000004 : ntdll!CsrSetPriorityClass+0x40
00000000`715ef1a0 00000000`77461a17 : 00000000`00000000 00000000`77464061 00000000`715ef750 00000000`00000000 : ntdll!RtlIsDosDeviceName_U+0x9475
00000000`715ef690 00000000`7744c32e : 00000000`715ef750 00000000`00000000 000007ff`fffd4000 00000000`00000000 : ntdll!RtlCreateTagHeap+0xa7
00000000`715ef700 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!LdrInitializeThunk+0xe
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ntdll!CsrSetPriorityClass+40
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntdll.dll
STACK_COMMAND: ~0s ; kb
FAILURE_BUCKET_ID: WRONG_SYMBOLS_80000003_ntdll.dll!CsrSetPriorityClass
Followup: MachineOwner
0:000> .ecxr
Unable to get exception context, HRESULT 0x8000FFFF
0:000> kb
RetAddr : Args to Child : Call Site
Bernard
Enter this command .sympath SRV*c:\symbols*http://msdl.micrososft.com/download/symbols and next issue .reload command.
Your call stack needs to be fully resolved I need to see function calls and parameters.Your call stack should look like this example
0000024c 00000000 00000000 NTDLL!ZwWaitForSingleObject+0xb 76ab8000 76a815ef 76ab8070 NTDLL!RtlpWaitForCriticalSection+0×9e 76ab8070 76a844f8 00cd1f38 NTDLL!RtlEnterCriticalSection+0×46
emreka82
Also, I run application verifier but get an error as follows:
0:000> !avrf
*** work. ***
Please fix the symbols for `ntdll.dll'.
Bernard
Issue this command ln 00000000774ccb60.
emreka82
You mean that ?
0:000> sxe 00000000774ccb60
0:000> g
(1054.1614): Stack overflow - code c00000fd (first chance)
3d!__chkstk+0x37:
00000001`3fe37137 41c60300 mov byte ptr [r11],0 ds:00000000`001f3000=00
How can I search for this "00000000774ccb60" address ?
Bernard
Please fix your symbols.We cannot proceed further.
emreka82
Ok, how can I fix it? I write .symfix on the command line, isn't it the solution of it ? Thanks.
OK. now I found it. I write symfix and then reload. Everything is fine in windbg now. The output is a bit long though:
0:000> .symfix
0:000> .reload
Reloading current modules
0:000> !analyze -v
FAULTING_IP:
3d!MG_CUTCELLREFINE+8d5
00000001`3f9b3941 b801000000 mov eax,1
ExceptionAddress: 000000013fe37137 (3d!__chkstk+0x0000000000000037)
ExceptionCode: c00000fd (Stack overflow)
NumberParameters: 2
Parameter[0]: 0000000000000001
Parameter[1]: 00000000001f3000
DEFAULT_BUCKET_ID: STACK_OVERFLOW
ERROR_CODE: (NTSTATUS) 0xc00000fd - Y
EXCEPTION_CODE: (NTSTATUS) 0xc00000fd - Y
EXCEPTION_PARAMETER1: 0000000000000001
EXCEPTION_PARAMETER2: 00000000001f3000
RECURRING_STACK: From frames 0x3 to 0x3
NTGLOBALFLAG: 70
APPLICATION_VERIFIER_FLAGS: 0
APP: 3d.exe
PRIMARY_PROBLEM_CLASS: STACK_OVERFLOW
BUGCHECK_STR: APPLICATION_FAULT_STACK_OVERFLOW
LAST_CONTROL_TRANSFER: from 000000013f9b3077 to 000000013fe37137
STACK_TEXT:
00000000`001f4838 00000001`3f9b3077 : 00000000`001f48a0 00000001`3f9b326c 00000000`00000000 00000000`00000000 : 3d!__chkstk+0x37
00000000`001f4850 00000001`3f9b326c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0xb
00000000`001f4860 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`001f6050 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`001f7840 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`001f9030 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`001fa820 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`001fc010 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`001fd800 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`001feff0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002007e0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00201fd0 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`002037c0 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00204fb0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002067a0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00207f90 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00209780 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0020af70 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0020c760 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0020df50 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0020f740 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00210f30 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00212720 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00213f10 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00215700 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00216ef0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002186e0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00219ed0 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0021b6c0 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0021ceb0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0021e6a0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0021fe90 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00221680 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00222e70 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00224660 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00225e50 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00227640 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00228e30 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0022a620 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0022be10 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0022d600 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0022edf0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002305e0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00231dd0 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`002335c0 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00234db0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002365a0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00237d90 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00239580 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0023ad70 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0023c560 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0023dd50 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0023f540 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00240d30 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00242520 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00243d10 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00245500 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00246cf0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002484e0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00249cd0 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0024b4c0 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0024ccb0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0024e4a0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0024fc90 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00251480 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00252c70 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00254460 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00255c50 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00257440 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00258c30 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0025a420 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0025bc10 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0025d400 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0025ebf0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002603e0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00261bd0 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`002633c0 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00264bb0 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`002663a0 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00267b90 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00269380 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0026ab70 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0026c360 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`0026db50 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`0026f340 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00270b30 00000001`3f9b326c : 00000000`71fc7830 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00272320 00000001`3f9b3941 : 00000000`7317ff38 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x200
00000000`00273b10 00000001`3f9b3941 : 00000000`733cff50 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
00000000`00275300 00000001`3f9b326c : 00000000`73184068 00000000`715ede98 00000000`00000000 00000000`00000000 : 3d!MG_CUTCELLREFINE+0x8d5
FOLLOWUP_IP:
FAULTING_SOURCE_LINE: E:\bolum\Doktora\Kodlar\3d\3d\3d\mg_cutcellrefine.f90
FAULTING_SOURCE_FILE: E:\bolum\Doktora\Kodlar\3d\3d\3d\mg_cutcellrefine.f90
FAULTING_SOURCE_LINE_NUMBER: 26
FAULTING_SOURCE_CODE:
22: call mg_cutcellrefine(neu%ng(i)%pp,cs)
23: !print*, 6
24: end if
25: end if
> 26: end do
27:
28: ! EDGE NEIGHBORS
29: do edgeno=1,12
30: !print*, 7
31: if (edgeno==1) then
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: 3d!MG_CUTCELLREFINE+8d5
MODULE_NAME: 3d
IMAGE_NAME: 3d.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 514c4dca
STACK_COMMAND: dt ntdll!LdrpLastDllInitializer BaseDllName ; dt ntdll!LdrpFailureData ; ~0s ; kb
FAILURE_BUCKET_ID: STACK_OVERFLOW_c00000fd_3d.exe!MG_CUTCELLREFINE
BUCKET_ID: X64_APPLICATION_FAULT_STACK_OVERFLOW_3d!MG_CUTCELLREFINE+8d5
0:000> .ecxr
0:000> kb
Bernard
>>>Issue this command ln 00000000774ccb60>>>
Leave this for a moment.
Please fix your symbols next run under debugger your app use !analyze -v next issue .excr command , next dump the scall stack with kb command and post the call stack.
It seems that you have multiple issues with your code.One of the easiest to debug is the issue with access violation (0:000> sxe c0000005).Please reproduce this exception.
Bernard
Issue !address 00000000`715ede98  command and post the result.
Bernard
Next dump raw stack data with this command !teb you will see two values stack base and stack limit.Issue this command dds value of stack base value of stack limit.Next issue r command (to dump registers) and use K command with the values of ebp esp and eip.It should look like this k L=some size of stack ESP EIP
You need to see at which instruction the overflow started.
emreka82
I have given the previous commands on my previous answer. The rest is:
0:000> !address 00000000`715ede98
Mapping file section regions...
Mapping module regions...
Mapping PEB regions...
Mapping TEB and stack regions...
Mapping heap regions...
Mapping page heap regions...
Mapping other regions...
Mapping stack trace database regions...
Mapping activation context regions...
Usage: Stack
Base Address: 00000000`00201000
End Address: 00000000`71600000
Region Size: 00000000`713ff000
State: 00001000 MEM_COMMIT
Protect: 00000004 PAGE_READWRITE
Type: 00020000 MEM_PRIVATE
Allocation Base: 00000000`00200000
Allocation Protect: 00000004 PAGE_READWRITE
More info: ~0k
Bernard
@emreka82
Could you have an infinte recursion?Regarding the disassembling the offending function please look at sub esp instruction and for loop terminating logic., did your code use recursive function calls?
Bernard
What is the implementation and signature of the offending function 3d!MG_CUTCELLREFINE?What are parameters passed to this functions? Regarding this address 00000000`715ede98 can you run d*p 00000000`715ede98 command inorder to dereference the supposed pointer?
Bernard
Can you post the source code of 3d!MG_CUTCELLREFINE between the line 11 and line 26?
emreka82
>>>>>Next dump raw stack data with this command !teb..........
0:000> !teb
TEB at 000007fffffde000
ExceptionList: 0000000000000000
StackBase: 0000000071470000
StackLimit: 0000000000071000
SubSystemTib: 0000000000000000
FiberData: 0000000000001e00
ArbitraryUserPointer: 0000000000000000
Self: 000007fffffde000
EnvironmentPointer: 0000000000000000
ClientId: 000000000000141c . 0000000000000a74
RpcHandle: 0000000000000000
Tls Storage: 000007fffffde058
PEB Address: 000007fffffdd000
LastErrorValue: 0
LastStatusValue: c0000135
Count Owned Locks: 0
HardErrorMode: 0
>>>>>>you will see two values stack base and stack limit.Issue this command dds value of stack base value of stack limit.......
0:000> dds 0000000071470000
00000000`71470000 00000020
00000000`71470004 00000000
00000000`71470008 00000000
00000000`7147000c 00000000
00000000`71470010 000029b0
00000000`71470014 0004cde0
00000000`71470018 0005cc40
00000000`7147001c 00062e98
00000000`71470020 0368298a
00000000`71470024 00000000
00000000`71470028 02200000
00000000`7147002c 00000000
00000000`71470030 00090268
00000000`71470034 02280008
00000000`71470038 00080008
00000000`7147003c 00090228
00000000`71470040 02280008
00000000`71470044 0008000a
00000000`71470048 00080220
00000000`7147004c 02200000
00000000`71470050 00000009
00000000`71470054 000a0248
00000000`71470058 02100048
00000000`7147005c 0048000b
00000000`71470060 000b0210
00000000`71470064 02100448
00000000`71470068 00480005
00000000`7147006c 00050210
00000000`71470070 02100448
00000000`71470074 0440000b
00000000`71470078 00040210
00000000`7147007c 02100048
0:000> dds 0000000000071000
00000000`00071000 00000000
00000000`00071004 00000000
00000000`00071008 00000000
00000000`0007100c 00000000
00000000`00071010 00000000
00000000`00071014 00000000
00000000`00071018 00000000
00000000`0007101c 00000000
00000000`00071020 00000000
00000000`00071024 00000000
00000000`00071028 00000000
00000000`0007102c 00000000
00000000`00071030 00000000
00000000`00071034 00000000
00000000`00071038 00000000
00000000`0007103c 00000000
00000000`00071040 00000000
00000000`00071044 00000000
00000000`00071048 00000000
00000000`0007104c 00000000
00000000`00071050 00000000
00000000`00071054 00000000
00000000`00071058 00000000
00000000`0007105c 00000000
00000000`00071060 00000000
00000000`00071064 00000000
00000000`00071068 00000000
00000000`0007106c 00000000
00000000`00071070 00000000
00000000`00071074 00000000
00000000`00071078 00000000
00000000`0007107c 00000000
0:000> r
rax=00000000000017e0 rbx=0000000071f373f8 rcx=0000000071f37820
rdx=000000007146dca8 rsi=000000007146dce0 rdi=0000000071ab94c0
rip=000000013ff07137 rsp=0000000000074648 rbp=00000000000746b0
r8=0000000000008000 r9=0000000000000012 r10=0000000000072000
r11=0000000000073000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010206
3d!__chkstk+0x37:
00000001`3ff07137 41c60300 mov byte ptr [r11],0 ds:00000000`00073000=00
0:000> k 000000013ff07137
Requested number of stack frames (0x13ff07137) is too large! The maximum number is 0xffff.
^ Range error in 'k 000000013ff07137'
0:000> k 0000000000074648
Requested number of stack frames (0x74648) is too large! The maximum number is 0xffff.
^ Range error in 'k 0000000000074648'
0:000> k 00000000000746b0
Requested number of stack frames (0x746b0) is too large! The maximum number is 0xffff.
^ Range error in 'k 00000000000746b0'
I try to apply your suggestions, cannot see ESP EIP or EBP in the code...Also as you can see, it gives a range error. I think that I have a mistake here.
