29348 Discussions
13.0 compiler bug/RTE: data entities finalized when they shouldn't be
Neil_Carlson
The 13.0 compiler is finalizing the result of a function reference which returns a pointer to a finalizable data type.  This is incorrect -- a pointer is not a finalizable data entity (see 1.3.76 and 4.5.6.2 item 1; the target of the pointer is finalizable, but it is only finalized when the pointer is explicitly deallocated.)  I've attached a short example that illustrates the error.  This is a really nasty bug that renders finalization mostly unusable, at least in my use cases.
-Neil
Anonymous66
Valued Contributor I
Thank you for reporting this issue. I have escalated it to the developers. The issue number is DPD200237182. I post any updates I receive to this thread. Regards, Annalee Intel Developer Support
Anonymous66
Hello Neil, A fix has been found for this issue. We are planning to include it in the next update which is currently scheduled for late January. Regards, Annalee
Anonymous66
Hello Neil,
This is issue has been fixed in Intel® Fortran Composer XE for Linux* 2013 Update 3 which is now available at the Intel® Registration Center.
Annalee
