FYI,
17.07 compiler crashes with the code below. Workaround is to initialize the procedure pointer with "=>Null()". Support ticket has been submitted.
Module test Interface Module Subroutine bla1() End Subroutine end Interface Procedure(bla1), pointer :: pbla=>bla1 end Module test Submodule(test) subtest contains Module Procedure bla1 end Procedure end Submodule subtest
Indeed this gives an ICE with ifort 17.07. This seems to work at least with ifort 18.0.3 and ifort 19.0.0.
I have encountered a very similar problem, which was present in ifort19 beta, and which is not fixed in ifort19 (have not tested it, but was told so by support):
It is essential that (see code below):
(1) character(len=:) is used as type of result.
(2) the abstract interface ifc and the function fun are in a separate module.
I also found out that with integer instead of character(len=:) it works, but with logical it also fails...
All in all, I am a bit surprised that a beta version is made available, but almost no bugs I have reported where fixed (though most were not really serious). But this one is a bit cumbersome to work around (in the end I have copied the few concerned routines into the module where I required them).
module bar implicit none private public ifc public fun abstract interface function ifc() result(x) character(len=:), allocatable :: x end function ifc end interface contains function fun() result(x) character(len=:), allocatable :: x x = '' end function fun end module bar
module mod use bar implicit none private type, public :: t procedure(ifc), nopass, pointer, public :: f => fun end type t end module mod
