29343 Discussions
64 bit compile: Error: There is no matching specific subroutine for this generic subroutine call. [QSORT]
andrew_terekhov
I use Visual C++ 8 (.Net 2005) IDE to invoke Intel Fortran 9.1. 32 bit version builds without any problem, but for 64 bit configuration I have the error:
Any help would be greatly appreciated.
Andrew
What are the datatypes of the arguments? As supplied, QSORT does not have a signature for INTEGER(8) arguments, but you can extend the generic to add your own signature and supply an appropriate compare routine.
andrew_terekhov
Thank you for the prompt reply.
Here is the code:
! vars declarations
integer(4) num_run
integer(4) sortElementSize
REAL(8) pointLossDistribution(num_run)
integer(2), external :: compareDescendReal8Function
! invocation
sortElementSize = 8
CALL qsort( pointLossDistribution, num_run, sortElementSize,
& compareDescendReal8Function)
! comp func definition
integer(2) function compareDescendReal8Function(arg1, arg2)
REAL(8) arg1, arg2
if (arg1 > arg2) then
compareDescendReal8Function = -1
elseif (arg1 < arg2) then
compareDescendReal8Function = 1
else
compareDescendReal8Function = 0
endif
Andrew
Ah -I was mistaken about the lack of a signaturefor I8, though that's not your problem.
Change::
integer(4) num_run
to
integer(SIZEOF_TIME_T) num_run
integer(SIZEOF_TIME_T) sortElementSize
On Intel 64, the length and size arguments are INTEGER(8). Using the above definitions will be correct on both 32 and 64-bit platforms. If you pass or accept these variables as arguments, make sure the corresponding declarations are also correct.
drle
Hello Andrew,
can you tell me which options do you use to compile your codes?
Thoi.
