Access violation in assignment(=)
Wolf_W_
i got an error with the XE17.1 compiler. The following code produces two different crashes in line 35 (coming from 68), dependend on the type of "vec" in "T_VECTOR". The code worked with the XE16.X compilers.
module M_T_VECTOR
  implicit none
  type :: T_VECTOR
!forrtl: severe (408): fort: (7): Attempt to use pointer ASSIGN_SOURCE when it is not associated with a target
    real :: vec(1:3) = [0.0,0.0,0.0]
!forrtl: severe (157): Program Exception - access violation
!    doubleprecision :: vec(1:3) = [0.0,0.0,0.0]
  contains
    procedure :: assignTo
    generic :: assignment(=) => assignTo
    procedure ::add
    generic :: operator(+) => add
  end type T_VECTOR
  type, extends(T_VECTOR) :: T_VECTOR_EXT
    type(T_VECTOR),  allocatable :: disp(:)
    class(T_VECTOR_EXT), pointer :: pt_a    => null()
    class(T_VECTOR_EXT), pointer :: pt_b(:) => null()
  end type T_VECTOR_EXT
contains
  elemental subroutine assignTo(assign_target, assign_source)
    class(T_VECTOR), intent(inout) :: assign_target
    class(T_VECTOR), intent(in   ) :: assign_source
! Exception thrown here
    assign_target%vec = assign_source%vec
  end subroutine
  elemental function add(lhs, rhs) result(ergebnis)
    class(T_VECTOR), intent(in   ) :: lhs, rhs
    type(T_VECTOR)                 :: ergebnis
    ergebnis%vec = lhs%vec + rhs%vec
  end function
end module M_T_VECTOR
program main
  use M_T_VECTOR
  implicit none
  type(T_VECTOR_EXT), target :: a,b(2)
  a%pt_b => b
  a%pt_a => a
  allocate(a%disp(2))
  allocate(b(1)%disp(2))
  allocate(b(2)%disp(2))
  !This works
  a%pt_a%disp(1) = a%pt_a%disp(1) + a%pt_b(1)%disp(1)
  a%pt_a%disp(2) = a%pt_a%disp(2) + a%pt_b(1)%disp(2)
  !This crashes
  a%pt_a%disp(:) = a%pt_a%disp(:) + a%pt_b(1)%disp(:)
end program
Greetings
Wolf
jimdempseyatthecove
Try adding ", target" to lines 6 and 21
Jim Dempsey
Wolf_W_
Thanks for your advice, but that gives me the compile-time error:
error #6516: This attribute specification is not valid for a component definition statement.   [TARGET]
Wolf
Kevin_D_Intel
Thank you for the concise test case. I reproduced the access violation for both data types noted in the test case and escalated this to Development (internal tracking id noted below).
I was unable to reproduce the noted "forrtl: severe (408): fort: (7)" failure on Linux and I do not have 17.0 update 1 available for Windows at the moment. This appears to be a regression with the latest 17.0 update 1. I confirmed as you noted the test case compiles/runs successful with previous 16.0 compilers, and I also found it runs successfully when using the initial 17.0 release (Version 17.0.0.109 Build 20160721) on both Linux and Windows. I will let you know if I learn about any source code work around for this defect.
(Internal tracking id: DPD200416395)
Wolf_W_
Thank you,
it can be worked around with a loop.
Wolf
Kevin_D_Intel
Ok, thank you for sharing that.
FortranFan
Kevin D. (Intel) wrote:
.. I will let you know if I learn about any source code work around for this defect. ..
@Kevin D. (Intel),
You may want to run the following with your development and see if it helps any in terms of diagnosing the defect with compiler 17.  I'm pressed for time to go into my observations of Intel Fortran and interpretations of the standard, but I've run into issues previously with coders in our team defining generic assignments with a polymorphic right-hand side and often it leads to ambiguities too.  See the effect of changing the declaration of the second parameter in the assignTo procedure below.
module M_T_VECTOR
   implicit none
   type :: T_VECTOR
   contains
      procedure ::add
   end type T_VECTOR
contains
      type(T_VECTOR),  intent(in   ) :: assign_source  !<-- see change here
   end subroutine
   end function
program main
   use M_T_VECTOR, only : T_VECTOR_EXT
   implicit none
   a%pt_b => b
   a%pt_a => a
   allocate(a%disp(2))
   b(1)%disp(1)%vec = 1.0
   b(1)%disp(2)%vec = 2.0
   print *, "a%disp(1)%vec = ", a%disp(1)%vec, " (expected values are all 1.0)"
   print *, "a%disp(2)%vec = ", a%disp(2)%vec, " (expected values are all 2.0)"
   stop
end program
Upon execution with compiler 17, update 1:
 a%disp(1)%vec =  1.000000 1.000000 1.000000  (expected values are all 1.0)
 a%disp(2)%vec =  2.000000 2.000000 2.000000  (expected values are all 2.0)
Kevin_D_Intel
Thank you FortranFan. I shared your update with them. Yours produces unexpected results w/17.0 initial release and expected results w/17.0 update 1.
