29649 Discussions
Allocatable array elements (in user types) and pointers
Kamil_Kie
I write this topic again, becouse last one was totaly wrong, example code have bugs and topic text was chaotic. I correct it, but probably nobody look on it now (http://software.intel.com/en-us/forums/topic/338043) . So  I decide to create new one - (if you are moderator or admin, please delete my previous topic, and not delete this one).
Becouse in my calculation I use very complicated formulas, and data types, for me is extremly important to have ability to alias allocatable arrays elements. For me is alsow very important to use allocatable arrays - not other constructions. Below you have 2 codes. First one use trick and work, second don't use trick and doesn't work.
[fortran]
program PointerBugSol
type :: StatisticOutMeridItem_type
character :: name*(32)
real, allocatable :: m(:,:)
end type
type :: Statistics_type
real :: avgValM
type(StatisticOutMeridItem_type), allocatable :: collectStatisticsMeridItems(:) ! (CSMI)
end type
type(Statistics_type) statistics
type(StatisticOutMeridItem_type), pointer :: p
integer :: i,j,k
!---------- Initialize
allocate(statistics%collectStatisticsMeridItems(3))
do k=1,3
allocate(statistics%collectStatisticsMeridItems(k)%m(10,10))
statistics%collectStatisticsMeridItems(k)%m=k+1
print *,"values on init:",statistics%collectStatisticsMeridItems(k)%m(1,1),k
statistics%collectStatisticsMeridItems(k)%name="test"
end do
!------------- Run test
call ptrGet(statistics%collectStatisticsMeridItems(1),p) ! now p is alias to st%collectStatisticsMeridItems(1)
p%m=(p%m+1)*p%m + (p%m*2.1)**(p%m-1) - 3./p%m + p%m**2
call ptrGet(statistics%collectStatisticsMeridItems(2),p) ! now p is alias to st%collectStatisticsMeridItems(2)
p%m=(p%m+1.5)*p%m + (p%m*3.1)**(p%m-1) - 4./p%m + p%m + (p%m+31)*p%m + (p%m*2.1)**(p%m-2)
!------------- Veiw results
print *,"After test:"
do k=1,3
print *,"values on stop:",statistics%collectStatisticsMeridItems(k)%m(1,1),k
end do
contains
subroutine ptrGet(el,r)
type(StatisticOutMeridItem_type), target :: el
type(StatisticOutMeridItem_type), pointer :: r
r => el
end subroutine
end program
[/fortran]
Second code:
[fortran]
end type
real :: avgValM
type(StatisticOutMeridItem_type), allocatable, target :: collectStatisticsMeridItems(:) ! (CSMI)
end type
integer :: i,j,k
do k=1,3
end do
p=>statistics%collectStatisticsMeridItems(1)
p=>statistics%collectStatisticsMeridItems(2)
!------- Show results
do k=1,3
end do
end program
[/fortran]
I use ifort 12.0.4 , for compilation and for run I type following line:
ifort PointerBugSol.f90
a.out
Here is compilation message:
PointerBug1.f90(32): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute. [STATISTICS]
The differences is that in line 09 in second code attrib "target" appear, and in first code we use tricky function "ptrGet" (ilnes 25 and 28). In second code we use direct way to get pointer (lines 25 and 27)
Why first code works, but second code don't ? There exist non-tricky , direct way, to get pointer to allocatable array element in user define type?
Kamil_Kie
One person give me answer: "change type(Statistics_type) statistics to type(Statistics_type), target::statistics" It works, and now everything is clear. I have deadlock in my head - I don't see it. However there is some back door in ifort which allow to skip word "target" and use subroutine (ptrGet) ...
I think you got some good answers in the other thread. You should not be looking for "tricky, indirect, back door" methods and instead stick to what the standard provides.
