Hi
I am using Intel Fortran 19.0 Update 8.
I ALLOCATE a large array 'X(M,M)' for simultaneous equation solutions over many time steps. At some point the model decreases in size where "M" becomes smaller.
I use the DEALLOCATE statement for array 'X' and want to ALLOCATE 'X(N,N)' for the smaller array.
Is there any way to do this within the program for the time step solutions continuing? It appears that "X" has lost its double precision definition.
Dennis
Can you show us a small reproducer? The precision of a variable/array is fixed by its declaration, so I do not see how it can loose its "double precision definition". The exception is if X is a unlimited polymorphic variable, but that seems unlikely for a variable participating in a numerical calculation.
Ideally, such a reproducer is a standalone buildable program that exhibits the same behaviour, but that may be difficult to achieve. In that case, could you at least show relevant code, including the declarations?
Barring compiler bug....
For this to occur, you may have omitted IMPLICIT NONE, and failed to declare X as double precision.
I suggest you place X in a module (as opposed to in a named common), and USE the module.
Jim Dempsey
! Four modules are called from the main program. Base holds the underlying FORTRAN elements such as dp etc.
subroutine analysis(count, ki, filename, num, numC, KR, MTYPE, NL)
use SMA
use Elements
use SaveESM
use Solver
Use Scotia
use ACADDraw
! Implicit none is standard
! Integer variables
implicit none
Integer Triangles ! Number of triangles in the model
Integer Beams, BeamNum, FrameNum
Integer I ! Loop counter
Integer count1,ig,jg,k,ll,count3, ndf
Integer Loop
Integer MTYPE
Integer NL
Integer loopCycle
integer beamID(mt1)
Integer O(mt1)
REAL time1(2) ! Holds the numbers for the run time calculation
REAL timeA
REAL (KIND=dp) scale
REAL (KIND=dp) ki(mn_6)
REAL (KIND=DP) OffStep(mt1,mn_4)
REAL (KIND=dp) CORD(mt1,ml2)
REAL (KIND=dp) num(ml1)
integer Frame(mt1)
integer MCON(mt1,mn1)
integer count
integer NM
integer flag
integer :: A_limit = limit
CHARACTER filename*60
REAL (KIND=DP) NUMC(ml30, mn_3),KR
! Type variables model holds the overall model data and Triangle holds data for each triangular element
TYPE (Model), TARGET :: ModelA ! Model for the FEM
TYPE (Triangle), allocatable, TARGET :: sTriShells(:) ! Each triangle that makes up the FEM model
TYPE (sbeam), allocatable, TARGET :: sBeams(:)
TYPE (aBeam), allocatable, TARGET :: saBeams(:) ! Each beam that makes up the FEM model
! Routine opens the files used for data input and output
! Base is the ultimate lowest module to allocate the file numbers, si, sw, sa, slog
call Files(1, filename)
!call OpenFiles(si,sw,sa,slog,srA) Not used at this stage
! Set up the model type used to hold the main details of the overall model
Call SetModel(ModelA, Triangles, BeamNum)
! Allocate memory for the triangular elements
ALLOCATE (sTriShells(Triangles), ModelA%indexM(3,ModelA%MaxNodeNumber), ModelA%nodes(ModelA%MaxNodeNumber),ModelA%noderesults(ModelA%MaxNodeNumber,mn_6),ModelA%offsetnodes(ModelA%MaxNodeNumber),ModelA%nodeloads(ModelA%MaxNodeNumber,6), ModelA%temploads(ModelA%MaxNodeNumber,6),ModelA%windloads(ModelA%MaxNodeNumber,6),ModelA%nodeWeight(ModelA%MaxNodeNumber),sBeams(NTA), saBeams(Beamnum), STAT=astat)
IF (astat.NE.0) then
STOP 'Could not allocate Shells or Model'
endifI know this works without problems, well not computational problems.
A sample of what Jim is talking about.
