29653 Discussions
Allocation failure for automatic array with /Qtrapuv
Andrew_Smith
Valued Contributor I
I get a status code of 151 and the array comes back with a size but with all elements showing undefined address. Only happens if /Qtrapuv is on. Can produce heap corruption warning too with more variables allocated.
UsingVS2005 SP1,Intel Fortran 10.1.0.24, Windows XP64 SP2
program
BugTestAutomaticArray
implicit none
integer status
real*4, allocatable, automatic :: a(:)
allocate(a(10), stat = status)
a = 1.0
end
program
I don't normally use automatic but it was an experiment to see why I am getting problems with OpenMP with random results after many weeks of debugging. OpenMPsets all local variables as automatic butin this case I don't get the allocation error but I do get some strange initial values.
This is a compiler bug, but also your bug as you should check the status before using the array. The compiler is proceeding to fill in the descriptor for the array even though the allocation failed, and you get garbage values. The bug has already been fixed for a future release.
Andrew_Smith
Thankyoufor your quick reponse.smiley [:-)]
Have you fixed theinitial failure to allocate or just the garbage after a failure ? Hopefully the first bug.
I agea it is good practice to check the status after alloactions but this code was intended to crash, so not checking in this case helped to ensure it did!
We fixed the garbage after the failure. The failure to allocate with /Qtrapuv is a new one, but I recommend against using that option anyway as it is worthless in its current implementation. However, I will report that to the developers.
