Another bug with ASSOCIATED?
OP1
New Contributor III
This code illustrates another potential bug when CLASS, POINTER, and ASSOCIATED are mixed together. With the latest ifort and ifx the association status of CT changes after the call to S - I believe it should not.
PROGRAM P
IMPLICIT NONE
TYPE :: T
END TYPE T
CLASS(T), POINTER :: CT => NULL()
WRITE(*, *) 'Association status of CT: ', ASSOCIATED(CT)
CALL S(CT, NULL())
CONTAINS
    SUBROUTINE S(C, D)
    IMPLICIT NONE
    CLASS(T), POINTER, INTENT(INOUT) :: C
    TYPE(T), POINTER, INTENT(IN) :: D
    C => D
    END SUBROUTINE S
END PROGRAM P
Devorah_H_Intel
I was able to test this issue internally. It has now been escalated to compiler engineering for a fix. Thank you for reporting this to us.
Devorah_H_Intel
This issue is fixed in the 2025.1 ifx.
